Gateway laptop to phillips tv
I was trying to connect my gateway laptop to my phillips tv. and i was told i was doing a complicated way so i was wondering what is the best way to do this since the way i am trying is difficult
using a vga 15 pin cord to a rca(blue, red and green)
  • sonya_herrer Jun 25, 2009
    THe gateway is mt3703 and my tv has an s-video input as well!! my other tv has the vga to vga capability!! so i order a vga to vga a cord. should it work better! and how do i set it up on my laptop
  • sonya_herrer Jun 26, 2009
    so in other words the vga to vga cord is all i need to be able to see what im doing on my laptop on my TV?
  • 63 Answers
Hi, there, pleasy clarify the following:
What is your Gateway model? Is your TV an older tube type or a new HDTV? Does it have other input ports besides the standard cable input and the RCA you mentioned? You may be able to use S-Video if your laptop has the output port and so does your old TV. Or if you have a newer laptop that includes DVI and you have an HDTV, then you can use a DVI to HDMI cable which by the way will result in the best image quality.
Posted on Jun 24, 2009
  • Gonzalo More
    Gonzalo More Jun 25, 2009
    Connect the VGA to VGA cable with your laptop turned off. Upon turning on your laptop the image will appear in both screens, your laptop and TV. If it doesn't, simply press the Fn key in your laptop along with the appropiate key to switch between LCD, TV or both. In most DELL this will be Fn+F8, check the additional incons or drwaing on your F# keys, it should be pretty clear which one you need to press along with the Fn key to switch between displays.
  • Gonzalo More
    Gonzalo More Jun 27, 2009
    Yes, thats all you need. If you'd like the audio coming out of the TV or a Home Theater Receiver you'll need a separate audio cable (stereo plug to RCA). Have fun!
Why is my 42" Phillips LCD TV losing the picture about 1-2 seconds after turning it on? The blue power light at the bottom stay on even after the picture has gone away though.
Hi
Beware of doing anything to Philips brand TVs, without previous experience in service. This is the first thing I have to say to you.
Unlike other brand TVS, the Philips circuits are more complicated, and will be difficult to follow to a new-be. I think, you got me.
Please contact the authorized service center for Philips.
google.com/+GopakumarGopalan
Dec 06, 2016 | Televison & Video
Can someone help? My Gateway built-in webcam will not work.
If you did a factory reset ,and i wont work stll ,then you have a hardware failure
and is either a loose connection or a bad webcam that needs to be replaced ,cheap on ebay ,but then gain to be honest ,could be a lot things including a motheboard component ,
good luck
Dec 18, 2013 | Gateway Computers & Internet
Video Not Supported
You would be better trying to connect from the laptop VGA to the TV Scart. But you will still need to set your laptop up to output a screen resolution that the TV can display.
Sep 19, 2013 | Televison & Video
How to remove cover to fix a power port
It is a fragile but simple process use a plastic prying tool much like the ones in iphone repair kits to pry apart te outside of the laptop it will work just a little tricky
Apr 05, 2010 | Gateway MX6214 Notebook
I have a emachine laptop i cant get online everything else works tried everything keeps saying im connected but my ip address is wrong tried to manually fix it but it wont take wht do i do?
Networks can be a little complicated and very picky.
Much of it depends on how the network is set up. Many will allow you to use DHCP, which means you set the device to accept whatever IP configuration that the network assigns. Some require a set IP address, subnet make, gateway and DNS numbers.
You must know the IP address for the Gateway ( which is usually the main network connection device that connects the network to the internet) and DNS, which is often the same as the gateway, and the subnet ( which will often fill in when you tab from the IP address for the device), in order to manually fill in IP configuration on your laptop.
You need to speak to the person who set up your network so you can see how your device needs to be configured.
I hope you find this information helpful and informative. If you found it helpful, please leave postivie feedback for me.
Thank You,
Brian
Jan 25, 2010 | E-Machines eMachines Desktop PC
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Jan 08, 2010 | Gateway MT3705 Notebook
How do you connect a toshiba laptop to a hd tv
Most new TV's have a port that looks the same as he moniter connection.
Dec 31, 2009 | Computers & Internet
Connect my gateway laptop to my phillips tv
It is very difficult to hook a laptop to a TV using the method you are trying. To get it to work go into your display settings (right click on desktop, go to properties, settings tab) and drag the slider bar all the way to the left (to the lowest possible setting, the numbers should get smaller as you slide it). Then try again. Currently the resolution is not compatible with your TV.
Jun 24, 2009 | Televison & Video
Televison & Video Logo
220 people viewed this question
Top Televison & Video Experts
