Question about Samsung HLR5667W 56" Rear Projection HDTV
When I check for digital signal strength, the display says "good" but there are no bars. We get no reception on that channel.
    Champion:
  • 205 Answers
Unplug let set drain. with back cover off look for loose connection from vibration
Posted on Jun 28, 2009
My channel 87keep it country is breaking down and intermiting
Possible there is a problem with the station or perhaps it has moved.
It is also possible your aerial has been damaged/moved and is no longer able to receive fringe stations, if ch 87 is a fringe station.
Try checking the signal strength of that channel in the menu to ensure there is enough signal strength and quality for decent reception.
Try doing a retune.
Check the station's website for status.
Apr 07, 2018 | Cars & Trucks
How do I keep it on Digital? When I try and turn the channel, it goes to Video 1. It says Digital channel signal strength is low.
How to fix digital TV reception problems - Simplify Digital
www.simplifydigital.co.uk > Guides
SimplifydigitalJul 11, 2014 - This handy guide will help you fix simple digital TV reception issues with Freeview, satellite and cable TV set top boxes. ... If you're suffering from poor digital TV signal, it may be possible to fix reception issues quickly, at home. ... We're here to run you through how to fix TV ...
Digital television transition in the United States - Wikipedia ...
Dec 26, 2015 | Televison & Video
My channel 7 keeps freezing and comes up with no signal sometimes for days when it's though my my bush digital recorder box. But when it's just though the tv channel 7 works fine. What's going on??
Different digital boxes and tv's have different levels of RF gain. Some need more signal and some need less to work efficiently.
Possibly your Bush pvr needs a much stronger signal than your tv so the available signal is permanently on the threshold of reception and atmospheric conditions will some of the time reduce the available signal when reception will become impossible for the box but still be above the threshold for the tv set.
Modern Bush is not reknown for being a high quality brand and the purchasers of budget brand pvr's often discover reception or performance problems in fringe signal areas. Because a single aerial must receive a very wide range of frequencies it will be more efficient for some channels than others and so one channel could be a fringe channel and another channel produce a very strong frequency.
The signal strength and quality can be checked for each channel by selecting options in the menu in order to check this theory.
The problem might be solved by replacing the Bush pvr with a premium brand or replacing your aerial for a more efficient type. One of my friends had five different boxes before he gained a satisfactory performance and another friend three boxes and still has problems.
My installation has a new high gain wideband aerial on top of my 3 storey house and a distribution amplifier in the loft to keep the input lead short and the whole lot connected by very good quality double-wrapped co-ax.
I had to add different amounts of attenuation for each box or tv set but in spite of the signal being on average too strong and needing attenuating there are still channels for which the aerial is not as efficient and providing only a weak signal.
Feb 09, 2015 | Bush Televison & Video
Cannot change channel on my Dynex DX-L26-10a TV
Try checking the signal strength then run the scan again.
Checking the DTV signal strength
You can check the DTV signal strength to determine if you need to adjust your antenna or digital cable input. The higher the signal strength, the less likely you are to experience picture degradation.To check the DTV signal strength:
1.Press MENU. The on-screen menu opens.
2.Press < or > to highlight Channel, then press v. The Channel menu opens. The DTV signal strength is shown at the bottom of the menu.
3.Press EXIT to close the menu.
Oct 26, 2012 | Dell Vostro 200 PC Desktop
I cannot get reception on the flexible antenna which came with the Casio JY-70B Portable Color TV. I need the users manual
Small antennas are usually inadequate for digital reception except in very high signal strength areas. You must also perform a channel scan befor attempting to tune a channel.
Feb 18, 2011 | Televison & Video
Our new digital LCD tv occasionally suffers from picture breaking up and even total loss of signal, after some time, 5 to 15 minutes the signal is restored. Fiddling with the aerial run and connections has...
Tune to a strong channel.
Go into the menu. Find the Channel or Antenna whatever your tv calls it. Set the signal strength display.
If the signal strength show good and your picture is lost then a problem may be in the tv.
More than likely the antenna is not picking up a strong signal. Try rotating it some.
You can go to www.tvfool.com to see what stations are in your reception area.
Feb 13, 2011 | Televison & Video
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
No digital channels
Hi quinny 1982,
The first thing to check do is look in the manual on how to do a factory reset.
Once you've done that look at this page on how to check the signal strength the TV is receiving. Anything less than 50% and most tuners will not display a picture.
If the signal strength is okay then try another auto tune.
If your still having a problem then I'd suggest you you might have a faulty unit. However, a lot the time companies like to blame your reception area, TV Antenna (Ariel) or cable length or quality. Yes, old coaxial cable used for analogue TV is not very good when used with digital equipment (not a surprise)!
From what you've described, if you can only get a mono signal I'd be surprised it that's actually a digital channel.
Don't forget to check your Antenna connectors.
Hope this is helpful.
Best of luck.
Spare head 2.
Jan 04, 2008 | Samsung LN-R409D 40 in. LCD Television
Samsung HLR5667W 56" Rear Projection HDTV Logo
71 people viewed this question
Jerry Greenberg
Jerry Greenberg
