Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
I have a 25.4 cubic foot counter depth side by side, Ice maker still works however no water through the door
  • 520 Answers
The solenoid in the rear of the refrigerator has failed. Have it replaced and you will be back in business.
Posted on Jun 24, 2009
  • 508 Answers
Solenoid sticking find and free up lube with vaseline!!!GoodLuck to you!!!
My Whirlpool Gold Side by Side (counter depth) [model# GC3PHEXNS00] refrigerator stopped making ice. Water dispenser is still working, doesn't seem to be an obstruction in the line. What do I do?
Can be clogged water passing line or faulty water valve.But if you have already checked the water passing line and it seems clear, then its most probably the water valve.---------
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Sep 18, 2011 | Refrigerators
Home Depot lists a depth dimension for a GE refrigerator. Is the handle included in the depth dimension?
no. depth is measured from the back of the box to the front of the box but does not include the handles. The depth of the cabinet is used to determine if the doors will open sufficiently to clear countertops and half walls or appliances. Also helps determine if enough space will be available to open doors in small kitchens such as "c" shape, "L" shape or narrow galley kitchens. for small kitchens, the best frig is a side by side. The doors are smaller and less swing space is needed. A 25 cubic foot side by side uses less swing space then a 15 cubic foot single door. If you are worried about depth, you can also get a counter depth frig which will stick out past your countertops by about 2 inches rather then 8-10 inches with a standard frig. standard depth is about 28-36 inches from the back wall when plugged in. Handles get in the way most often in width measurements because they prevent the doors from swinging past 90 degrees if located next to a wall.
Dec 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser will not dispens ice . light dims when pushed. ice maker works fine
It may be a good Idea to remove the ice bin, clean and dry ant the same time with bin removed see if while pushing the door light switch and the dispense ice control if the auger fork in the rear of the ice bin that normally turns the auger will rotate. Sometimes ice or water collects in the bin and locks the motor from turning and sometimes the motors go bad. Tell me your results, Thanks, Sea Breeze
Apr 23, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Ice maker stopped working, red light is flashing, however water is working? What is the problem, how do I fix?
For the red light try removing or replacing your filter.
The ice maker usually has a make ice bar about it inside the freezer. The down position is usually on.
Dec 02, 2009 | Kenmore 23.1 cu. ft. Side-By-Side Counter...
No ice comes out of dispenser
Sounds like the ice bucket is not all the way into its slot. Im assuming the ice bucket is in the freezor and not attached to the door.
Oct 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Aug 10, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
81 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
