Question about Frigidaire FEQ1442ES Electric Dryer
Dryer how do u replace heating coil in frigidair front load dryer?
  • 4,889 Answers
There should be a removable kickplate found at the bottom of the dryer. Remove this kickplate by removing the two screws found at the bottom. Let the kickplate drop down just a little to disengage the two pins found on its top.
If your dryer has an enamelled top, you can raise it by releasing the two spring catches found under it. Use a putty knife (or some other thin and flat object) to push in on and disengage each catch.
Remove the two screws (some models will have four) that secure the bottom of the front panel. As you remove the front panel, disconnect the door switch and any other wiring, taking careful note of which wires are to be reconnected where.
If your dryer has a galvanized top, remove the screws from the front panel, and then remove the front panel itself. As you remove the front panel, disconnect the door switch and any other wiring, taking careful note of which wires are to be reconnected where.
Thats all you should gain access to the heating coil..
Posted on Nov 05, 2007
My dryer suddenly stopped drying today. It just blows cold air. Before I took notice of all the lint in dryer, I took the heating element coil out which doesn't look damaged.
The lint MAY have caused a thermal limit fuse to blow out. If that is the case then it has to be replaced. There is also a chance that the heater element has failed and as you saw it is like a light bulb coil. You need to inspect it very closely if you don't have an ohm meter to test it for continuity. Frigidaire 131553900 Heating Element Assembly PartSelect
Frigidaire 134120900 Thermal Limiter Limit 220 PartSelect
Dec 18, 2017 | Frigidaire Dryers
Where are fuses located in Frigidaire front loading dryer?
No fuses. Probably Heating element or one of the thermal switches. Electric dryer I am assuming
May 24, 2015 | Frigidaire Dryers
Frigidaire affinity dryer not heating up after replacing the heating element. It will heat up for a minute then goes cold but dryer keeps spinning.
did the original element bad? you probably replace the wrong part for the problem. check your coils, there's two of them right in front of the element.
Oct 13, 2013 | Dryers
Frigidaire dryer not drying clothes
did u clean out the vents inside and the hose vent leaving the house? if so then, it could be the control nob
Jun 07, 2012 | Frigidaire Dryers
Dryer is Electric. spins clothes but no heat?
What is the setting on for example towels,check lint trap in back when dryer turns does the back of drum turn red,look through door and watch. If you still don't feel heat its the coil,It should be under warrenty.
Jul 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
check for igniter to be glowing, remove the plastic tab on the front panel an start the dryer
if it glows igniter is ok takes about 30 seconds to glow.if it glows is ok.
then check the thermal fuse for conitnuity an if it checks ok
then you have bad coils. replace the coils an ur done
May 26, 2009 | Frigidaire GSGQ642A Gas Dryer
My Fridigidaire gasdryer will heat up for the first part of cycle
It sounds like the coil valves are not continuing to open.
If you can get the dryer open, (unit UNPLUGGED of course) you will see that the gas valve has two black cylinders on top of it with wires coming out. Electricity magnetizes these and that magnet is what opens the gas valve so that the dryer can heat. When they get old, the electricity starts to heat them up, and they stop working. You end up with a dryer that will heat up for the first 2 minutes of a load, and then stop heating.
The coils are very easy to replace, and are usually held in with a small bent metal plate and two phillips screws. Removing this plate and the coils doesn't interfere with the gas plumbing, but if turning the gas off makes you feel better, go ahead.
I'm not sure if those are the ones for your model or not, but that is what they will look like. Check the model number on the sticker inside the door to make sure you get the right ones. Be sure to get the kit of 2.
Apr 07, 2009 | Frigidaire Dryers
Changing heating element
No need to buy the whole pan. The replacement coil is way less. 5300622032
Very easy dryer to repair. Start by popping the top and then removing the front. Get te drum out and remove the heater assembly. Remove the old coil. NOTE: when replacing the new coil be vewy vewy careful not to stretch the coil too much as this causes a hot spot and shortens the life of the coil considerably as in like one load maybe. LOL.
Jan 31, 2009 | Frigidaire GLER642A Electric Dryer
Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Nov 23, 2008 | Frigidaire GLER642A Electric Dryer
Front load dryer
Remove the front panel to get to it. Once you get the front panel off it is easy to remove the drum and replace the element. First remove the top then the front then you have it.
Dec 19, 2007 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
109 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
