I have a pinstripe blue line down the middle of my screen. How do i fix it?
  • 458 Answers
Any type of line going down a screen indicates a fault with the screen itself, the only cure is to have the screen replaced. If it is still under warrenty there should be no problem, if it is older then the price of a new screen can be almost as costly as a new TV.
Posted on Jun 24, 2009
    Problem Solver:
  • 5 Answers
Put a fan behind it. Let me know if it works.
Posted on Jun 02, 2010
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
Top, middle of screen there is a constant flicker. The flicker starts at the top, middle and goes about half way down the screen.
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up the problem. On furthe investigation I replaced the air filter and kept only the original fan and the problem was solved. Can you explain this.
Dec 06, 2009 | Zenith D52WLCD 52" Rear Projection...
Horizontal Line running down my Laptop Computer Screen
You can try changing resolution to something else and then back.
You can see if your colors are 32-bit.
The fact that you "fixed" it is probably an coincidence. Once you start getting anomalies like that, it usually means a new screen.
Oct 03, 2009 | Dell Computers & Internet
Sky PDS4250 42'' Plasma TV - Black line down centre of screen
not sure if this is the fix or not ...but i was tryin to fix a problem with my tv(not the same as yours)...but in the menu under adanced you can split the screen ....when i do that it puts a blue line down the middle of the screen
Dec 04, 2008 | Protron PLTV-4250 42 in. LCD Television
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
Verticle lines through screen
Many times this is caused by a poor connection at the circuit board ribbon connectors to the boards, pull the TV cabinet off, unplug and re-plug all the connector to the boards a few times, take care not to damage them.
May 04, 2017 | Apple Cinema 20" LCD Monitor
Autiovox lcd Half the screen turns blue the other half has virtical lines in it.
Typical of the glue that holds the circuit to the screen coming loose.
it will take a very good repairman to fix this and he will have to know where to find the glue, its special with microbeads embedded.
Mar 03, 2008 | Televison & Video
Gateway monitor
its a separation of the connections between the drivers and the lcd panel.
its a fancy glue that only techs know how to get.
and even that may not fix it.
it may be a failure of the driver itself.
A well placed bang may fix it temporally.
only way to tell is to get a replacement screen.
I would just sell it on ebay you might be surprise how much it fetches.
Jan 30, 2008 | HP Compaq FP 7317 17" Flat Panel LCD...
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Televison & Video Logo
617 people viewed this question
Top Televison & Video Experts
