Question about Intel D865GBF Motherboard
Intel D865GBF, having sound-max, is not giving signal to speakers. While using sound-max wizard mic input signals are shown, but there comes no sound in speakers while testing it...
    Scholar:
  • 106 Answers
Goto the your Start button, control settings, sound, click advanced, make sure your mic is not muted, and the proper input is selected(usb, or however you mic is connected.) Make sure you get levels here when talking or tapping the mic lightly. Sound max should work if this is set correctly.
Posted on Jun 24, 2009
I have a TRV98 Hi8. Trying to convert Video 8 tapes to digital. Sound comes from the camcorder, but no sound coming through the converter to the computer. Using the s-video cord?
An S-VHS cable only carries video signals. You must connect a separate audio cable from the camera to the sound input on your computer. On a Windows computer this would be the Mic input, usually marked in pink. You may also have to make sure that the computer has the mic input turned on, which in Windows would involve the sound Mixer. The standard Windows mixer is accessed by double-clicking the little speaker symbol in the "tray" at the bottom right, but many sound cards have their own mixer utilities.
Nov 17, 2010 | Sony Handycam CCD-TRV68 Camcorder
I've tried several mics: mxl 990, Sure sm58/57, an AKG mic, and I get very low input signal or no signal at all from the mxl 990. The problem is the same regardless of phantom power. Cranking the input...
1. maybe the impedance of you mic did not match to your sound card..
2. sound card did not support you dynamic mic...try to use FET or condenser mic..
May 24, 2010 | Tascam US-1641 Sound Card
Brand new mixer pmp3000 and two brand new speakers (passive) new cables.. plugged in mic , signal is shown but no sound out of the speakers. why????
Make sure the slider switch is set to the correct mode.
The TRIM controls must be advanced while the sliders are at 70%.
A common problem is to MISTAKENLY plug 1/3 inch input cable into the Effects Insert jacks instead of the inout IF you use 1.4 instead of XLR inout.
Make sure the channels of interest are NOT muted!
Dec 05, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Mono
Hello sir/maam, most (almost all) mic are mono, and the microphone mixer circuit splits the signal to two channel left and right, and fed to two amplifiers, then to two speakers. IF by any chance only mono, we need to trace the path where the mic signal is fed, and where the signal dissappeared, check also your balance control.
If your mic mixer circuit is designed for one channel, contact your local tech to check out or make connection to both channel.
Oct 05, 2009 | Samson R21S Microphone
Intel D865GBF motherboard's onboard sound card is not giving signals to speakers . Sometimes only left speaker works but mostly none of them works. I tried many media players & many speakers. But while...
it is the problem with the back side motherboard sound port.
so u can purchase another sound card and install it. it cost about 6$ (Rs 300.00 )
If it helps RATE ME PLS
Jun 25, 2009 | Intel D865GBF Motherboard
My TAscam 122 is not picking up a signal from my mic leads?
What are your microphone settings in the BIOS (Basic Input Output System) in the pre-boot setup?
Apr 24, 2017 | Tascam US122 Audio/MIDI Interface with...
Mic problem , in my dell laptop
you can check the mic by going to
control panel>sound and audio devices>voice tab > test hardware
this will show you the input as well as output signal you can test your mic if the input signal is coming when you speak means your mic is working properly if not check the mic once is that in good condition or not ...
if needed replace the mic ..
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Sep 03, 2008 | Dell Latitude D600 Notebook
D865gbf audio drivers
hey guys here is the 100% working Intel audio sound max vista fix driver from my collection
still looking for the video ones ....
how t o use go to device manager and click update driver and chose location agree the prompt and you are all done note mic may not work in all pcs used and test on my dell dimension and on my Intel D865GBF enjoy guys
http://www.freewebs.com/locosmusic/Sound_max_vista_Update_driver.rar
Jul 24, 2008 | Intel D865GBF Motherboard
Wantind to add mics to my karaoke machine-Vocopro GiGMan karaoke system
I'd get a small mixer, then run mics into that, mix em down to 2 channels then send em to the karaoke machine, that way you have control in mixing multiple mics down to 2 channels, I wouldn't bother with 1/4 " mini plug mics or splitters personally.
A D.I. box ( direct injection ) takes an instrument or line level signal through a step down transformer and it comes out the other end as a mic level signal, the purposes of it are for running an electric instrument into it wich is split into 2, one for going to the input stage of a mic pre, the other can go back out to an instrument amplifier, this way you can run a direct signal into the console via " direct injection " into the mic pre as a mic level signal and also can run it to your instrument amplifier in order to be able to also mic the speaker cabinet acoustically at the same time, there are many benefits to this, for instance in live shows if the speaker cabinet or mic fails then you still have the direct signal, also since the direct signal tends to be punchier and clearer, cleaner, than an acoustically mic'd signal, they can both be mixed together at the console to give a a desired blend of each signal. Since there is a small delay between the direct signal and the acoustically mic'd signal because of distance of the mic from the soundsource delaying the direct signal a bit may be desired. D.I. boxes are only for instruments, they are superflous for vocals, the quality of the D.I. box does matter and active D.I.'s are the way to go, passives are as they are in speaker crossovers, less than desirable quality. There are also many tube D.I. boxes, generally a D.I. box isn't necessary for running an instrument into a consoles mic pre because most consoles take line level inputs as well, and there are other ways for getting a line level signal into a console by bypassing the mic pres anyways, If you have quality mic pres it's good to use them for the initial gain stage though as opposed to boosting instrument level to line level using a crappier preamp, for instance running an electric instrument input through an effects pedal will raise the instrument level to line level but of course an expensive mic pre will do a better job of it than an effects pedal will, since the first gain stage is paramount to quality......................
Nov 17, 2007 | Audio Players & Recorders
Soundmax drivers for Vista
try reinstalling the audio driver ... there is some conflict or bcoz of some problem it is not installed correctly....
Nov 12, 2007 | Intel D865GBF Motherboard
Intel D865GBF Motherboard Logo
91 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
