Question about Ricoh Aficio SP C410DN Laser Printer
Ricoh sp c410 yellow toner is offset in prints
My ricoh sp c410 offsets the yellow toner in every print - basically the yellow print is offset to the rest of the colors in the picture creating a yellow ghost effect. Why? and how can it be fixed?
  • Anonymous Mar 27, 2014
    ricoh sp c410 owners manual
    New Friend:
I had this same issue with my c430 but i tried doing the color registration and it went into error sc285. Any help?
Posted on Jul 31, 2014
  • 95 Answers
Go into the menu that says maintence )I think) and do the color registration.
Posted on Jun 26, 2009
How to reset this error :Fusing belt unit must be replaced now ricoh mpc 2503 SP
These machines have a internal counters to keep track of consumable parts. The part has reached its mark. it needs replaced. you can cheat the system by reseting the fuser counter to zero. It is just that cheating the system. You will encounter problems if you do such. Copy quality will be effected maybe not right away but it will happen. Offsetting print from one page to the other. It will be real noticeable on the edges of the paper. replace the fixing assembly.
Apr 09, 2017 | Ricoh Office Equipment & Supplies
How to reset replacement required print cartridge ricoh sp 3510/3500
"Replace Print Cartridge" remains in
display. Then a new AIO cartridge must
be installed. This feature is a safety
measure to prevent the used toner tank
from becoming full (there is no toner
overflow detection mechanism).
Dec 05, 2015 | Ricoh Aficio Sp 3510sf All-In-One Laser...
My printer does not print full black it comes out light and dark
Hello sir; The ricoh copier have toner save mode if youwant print whole page in black, then you have go to SP mode group 2 looking for "enforce toner adding" you have to executive for couple times otherwise you have not enough toner tocover whole page, enter SP mode you press "clear mode", "107", and then pree and hold "clear/stop" key until SP mode display, then touch SP mode on screen, touch group 2 looking for what you want.
Jun 03, 2009 | Ricoh Office Equipment & Supplies
How do I change the waste toner bottle for a ricoh sp c410?
Drill a 3/4" hole in lower left side of waste toner bottle. Waste toner is very fine and will get all over the place – you also may want a breathing mask. Take outside and dump waste in large ziplock bag and dispose properly. Put a large piece of shipping tape and cover hole. Put back into ricoh c410. This wi;; save you about $50 and less plastic in our landfills. SG
Jan 13, 2009 | Ricoh Aficio SP C410DN Laser Printer
Toner Cart chip reset for Ricoh Aficeo sp c400dn
I believe you will need to purchase and install a reset chip. You can find them for the Ricoh C410 here at www.cfriends.com (that links straight tothe ricoh page - but if you need to search, type in "c410" into the search field on their site).
Jan 03, 2009 | Ricoh Aficio SP C410DN Laser Printer
Printing from the wrong tray on the Ricoh C410 DN
these settings need to be done with the RPCS printer driver, go to properties and then custom settings from there you can tell the printer where to print from.
http://www.websitetoolbox.com/mb/copierquestions
Dec 30, 2008 | Ricoh Aficio SP C410DN Laser Printer
Glossy Paper descalibrates my Ilumina
suggestions...
first, make sure all your consumables are in good condition, run a configeration page and check the percentages....toners should be 10% or more.
drume should be 50% or more(depends on what weight stock u been running), but run the ID check print, to see drum results.
The transfer belt should be above 20%..
This will ensure your machine can deliver.
next, make sure you have the correct paper weight setting( both in front panel(web browser) and (application drivers) for the stock. If you have setting gtoo high, then over toning will occur.
also, stock must be suitable for laser printing, offset, or cheap paper will drive you nuts....
good luck
Oct 15, 2008 | Xante Ilumina Digital Color Press Printer
Error occurred SC285
I'm having the same exact problem. Has anyone come up with the answer to this issue? Our printer was dropped a little and hasnt worked quite right ever since.
Sep 12, 2008 | Ricoh Aficio SP C811DN-DL Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
Oki c5100n printing colors offset
posted by Halfwalkeer on Nov 13, 2007 Report abuse
Just replaced the color toner cartridges in the c5100N, two OKI (cyan and yellow) and one non-OKI (magenta). Now it appears that registration is completely off.
When printing an image, there is a band of yellow at the top about 6mm high, and a band of purple (not cyan) at the bottom about 6mm high. It seems that the yellow printing LED array is printing offset. I've verified this with a typical test page that shows yellow blipped up by several mm.
What the hell happened ? How can I fix it ?
Thanks -
Dean.
Comment by Halfwalkeer, posted on Jan 02, 2008 Drums are all at 34%. Please don't tell me that the drums only have a 50% lifetime on them, because that would just suck royally. When you say the problem is most likely drums, in what way ? What could have gone wrong ?
I was able to more or less fix the problem ... It took several iterations of ColorMenu->Adjust Registration followed by Maintenence Menu->Menu Reset, but it was finally able to pull the registration back into line.
I got worried at one point - after it was "fixed" the printer was powered off. Upon powerup again, registration was off by several centimeters ! Another round of the above finally "fixed" it again, but I haven't powered it down again.
It was a cheap printer. Maybe this is why ...
postsolution.gif Post Solution addwq.gif Work Queue sameproblem.gif Have the same problem? X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Jan 02, 2008 0%20stars.png
4d566c2.jpg Soulvisitor
Rank:guru_s.gif Guru
Rating: 86%, 674 votes
Comment by Soulvisitor, posted on Jan 02, 2008 I was thinking about the band of yellow being caused by cleaning blade wearing on drum, drums are garenteed by oki if over 50 %, under that one is on their own ie purchase new if having problems with them
If you can fix problem doing colour calibration then faulty drum is not likely the issue.
Cant stress how many problems are caused by non gen consumables in machines, highly dont recommend their use.
Ricoh Aficio  SP C410DN Laser Printer Logo
590 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
