Question about Husqvarna Viking 1
Remove housing on viking se
I removed all the screws on the back of the machine but can't get the housing off.Help
    Sniper:
  • 52 Answers
There are six screws on the back and 1 on the free arm cover after that there are two on the bottom, after removing all of those screws its easy if you hit the side by the handwheel and it should pop free. i really wouldnt recommend doing this if your not a certified viking tech as it will void your warranty
Posted on Jun 26, 2009
How do i dismantel a viking sewing machine 6000 model 6440?
You can remove the rear cover by taking out two screws on the back cover and a screw at the lower rear corner on the side. With this cover removed you can see most of the internal levers and mechanism and be able to access some (not all) components.
Jul 03, 2014 | Husqvarna Viking 1
Knife cutting knives
Remove the stichplate and snap out the plastic cover over the thread cutter (left most end of machine). This exposes the thread cutter mechanism. You should then be able to position the knife arm back into the mechanism (two pins on the cutter mechanism that insert in a hole in each actuating arm).
Apr 11, 2014 | Husqvarna Viking 1
Removing the covers on a viking 980
I assume you're talking about the main back and front cover. Unless you really are skilled, I'd leave this project to a professional.
I've worked on the Designer I, II type machine and I believe yours has similar construction. You need screwdriver bits with a 6 pointed "star" head. Screws in the cover itself are "H10" size. Screws in the base are "H15" size. The back cover has to be taken off first before you can get at screws for the front cover. Typically there are 5 screws on the back cover that have to be removed and 2 in the bottom of the base. Note that the front and back covers "snap" together and have to be unsnapped after the screws are removed. If you have to take off the front cover (requires removing more screws in the cover and base), be careful with the various wiring harnesses that attach to the main circuit board.
Jan 13, 2013 | Husqvarna Viking 1
How to put a thread cutter in husqvarna viking desinger se sewing machine
I believe the plastic cover (gray?) toward the end of the arm (left of the needle plate) is removable by prying (gently) on the front edge and sliding toward you. Unless the cutter is broken, you should be able to figure out how itall fits back together.
Dec 21, 2012 | Husqvarna Sewing Machines
Will not sew
Check your bobbin compartment for loose thread and or debris. This often causes the thread not to combine properly. There is also a tensioner screw on the bobbin housing that can be tightened/loosened to adjust the tension, this may be the problem. Most machines have a removeable bobbin housing via clips or screws, to remove the assembly and clean.Or you can direct your queries to:
http://www.husqvarnaviking.com/us/2821_3079.htm
Mar 17, 2010 | Husqvarna Viking 1
Removing needle plate from viking sewing machine
throat plate is usually tight with screws may be that the holding magnet and once the button is located near shuttle and it should press plate up...
Dec 24, 2009 | Husqvarna Viking 1
Husqvarna 2000 series (64 40) How to remove handwheel to replace handle screw.
Hi, to remove the handwheel on a Viking 6440 you just need to take two screw drivers, one on each side, and gently pry the handwheel off. Nothing else is keeping it attached. Many of these are just stuck a bit and need gentle prying.
Good luck.
Rick
Dec 07, 2009 | Husqvarna Viking 1
Husquarvana Viking model 630 needle doesn't move when powered up
if the balance wheel is moving round okay manualy it could be but it could be thread lock or just a tiny bit of fabric stuck in the workings
Jun 12, 2009 | Husqvarna Viking 1
Password For Viking Designer SE
actuall she/he means is after you hold down the back and pivot foot button and turn on the machine, it will pop up with a dialog asking for a password..
Jan 12, 2009 | Husqvarna Viking 1
Sewing Machines Logo
188 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
