Question about Powermatic 1352001 3520B 20x35" Wood Turning Lathe
Clicking noise coming from headstock spindle - Powermatic 1352001 3520B 20x35" Wood Turning Lathe
Looking for a live centre and drive end spur for a Mastercraft 554508-0 cast iron wood lathe
Such accessories tend to be universal rather than dedicated to any particular make or model of lathe.
Such accessories are available from many outlets and catalogues containing items for the wood-turning enthusiast.
The tailstock of most lathes would be produced with a Morse taper numbers 1, 2 or 3 and with a variety of adaptors a number of live or dead centres, drill chucks or morse taper drill bits can be used.
Similarly the headshock spindle should be found to have a standard thread capable of accepting a number of chucks, faceplates, drive spurs and so forth.
The headstock spindle thread and the tailstock taper should be listed in the machine specifications and then armed with that information you can shop around a multitude of suppliers to find the best deal.
Apr 19, 2016 | Tools & Hardware - Others
RF900R i press The Start button but nothing happens no click no nothing but stand the bike up and wiggle the handelbars it starts up. ket it sit and nuthing again i have a fully charged battery. please...
It sounds like the wiring harness could have a damaged wire. one of the most common places is where the loom comes out of the headstock. Check the harness for signs of wear. It can't be the main fuse if, by just turning the bars, it works again. It has to be a frayed wire shorting out in my opinion. If you do find a problem, to make it better after repairing get some of that spiral binding used for bookbinding and wrap around the loom where it comes through the headstock for future protection.
Jul 26, 2014 | 1997 Suzuki RF 900 RV
What is a headstock
at the front of the frame, the steering bearings(headstock bearings) sit in the headstock.
Mar 09, 2013 | Motorcycles
Diagram of inside the headstock of a bmx
you will have to purchase new one unless you can somehow salvage the old one and i have never seen it done.its just a little star like wedge with a screw hole very cheep.
Jan 18, 2013 | Mongoose 20-Inch Gravity Games BMX...
Where is chassis number on Honda FES 125 Pantheon 125?
The usual place to find the chassis number is on the headstock. This is because the headstock can't be changed as a spare part. The headstock is the point where the forks rotate in the frame.
Mar 13, 2012 | 2007 Honda FES 125 Pantheon
2006 Avalanche 2.0, hearing click-clack noise coming from crank under heavy pedaling- bearing noise???
It might be the bottom bracket bearing, but it is more likely to be the attachment of the crank arms to the spindle. There is a square hole in the crank arm that is tapered to fit tightly onto the the tapered square end of the bottom bracket spindle. You have to tighten the the nut (usually under a dust cover about the size of a quarter that you unscrew with a screwdriver). Both sides of course. It usually requires a thin-wall socket, or a special wrench designed for this purpose such as the one shown here.
http://www.parktool.com/product/crank-wrench-ccw-5 good luck.
Jul 04, 2011 | GT Avalanche 2.0
Making too much noise; not motor
hi there it could be a few things, but what i would do is take the back off and look at the spindle if you manually rotate the drum and the spindle is twisting its that! or as simple as it sounds i had the same issue but it was a underwire from a bra that had gone through the holes in the drum and wrapped all the way around the spindle! it was a pain to get out but the dryer up and running perfect now!
let me know how u get on
vic x
Mar 03, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Noisy headstock on 15 inch variable speed lathe
Usually not. Is lathe leveled, and base secured, check for soft feet. This can set up vibration and load bearings.If motor is belt drive check belt condition, pulley alignment, belt tension.
Jul 29, 2009 | Tools & Hardware - Others
Torque setting cbr 1000rr headstock nut?
Hi there!
here are some recommended torque for small nuts and bolts:
Torque Specifications of Small Screws
Screw Size/Torque (in.-lb)
2mm 5-7
2-56 6-8
2.5mm 8-10
4-40 10-12
5-40 11-13
3mm 12-14
6-32 15-17
4mm 18-21
8-32 19-23
5mm 20-24
10-32 22-26
Also, click on the link below and you'll never have to find torque settings for your motorcycle bolts. I use this as a reference all the time.
http://img399.imageshack.us/img399/4280/ac43131btable71torquevalues9cn.jpg
Hope this helps!
Mar 29, 2009 | 2007 Honda CBR 1000 RR Fireblade
93 honda accord howling noise coming from engine
hi try taking the air filter pipe off the throttle body see if the butterfly spindle has no play in the spindle or the retaining screws that hold it to the spindle have not come loose just put your finger on the butterfly while its idling see if the noise goes if not just pinch the vacuum hose on the vacuum box see if noise goes or changes pitch yates210456
Oct 12, 2008 | 1993 Honda Accord
Powermatic 1352001 3520B 20x35" Wood Turning Lathe Logo
69 people viewed this question
Top Powermatic Tools & Hardware - Others Experts
john h
Are you a Powermatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
