Question about HP Office Equipment & Supplies
Im trying to scan an image into my computer... but the printer is saying that its not connected... It is connected because I can print to it just fine...please help!
    Scholar:
  • 169 Answers
Chk for the scanner drivers in the control panel..try uninstall and reinstalling them if you see them...then try scanning from the computer first to see if the drivers are installed.if it works make sure you have the s/w properly installed to scan to the computer..
Posted on Jun 24, 2009
Scanner & Printer Features are missing in the system setting.
Print scan card not in unit? ( a SD card on left rear under a cover)
Feb 05, 2014 | Ricoh Aficio Mp171spf Copier,Fax,Net...
When i scan to computer it cannot download the application
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 26, 2012 | Lexmark X5650 ALL-IN-ONE PRINTER
How to scan soemthing onto a computer
Do you have the full-featured software driver installed? (Installed before connecting the printer to the computer.) Then you have the option of initiating the scan from the computer or the buttons on the unit. (The HP Digital Imaging Monitor Windows System icon should be in your system tray. If the program has been closed, restart the HP Image Zone software or reboot the computer.) There is a Start Scan button on the printer which should launch the HP software. Alternatively, start the Image Zone software and there should an option to start the scan.
These directions will only work if the computer and printer are both on and communicating with each other. If you get an error, try a new USB cable and try using a different USB port. If using a USB hub, try connecting to the computer directly. (If using a print server, try a direct connection. Check if the print server supports bi-directional communication; many only support the print functions not the scan options.)
I hope this helps.
Mar 22, 2010 | HP PSC 1510v All-In-One InkJet Printer
When trying to scan to my HP J4580 Officejet J4580 All-in-One printer it says "No scan options, refer to device documentation". What does this mean?
It means you need the HP scanning software running on your computer. The computer tells the scanner how to scan, what to scan and where to save the image after scanning. The scanner has no options until received from your computer.
Feb 09, 2010 | HP OfficeJet J4580 All-In-One Laser...
Printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Jun 05, 2009 | Lexmark X6570 InkJet Printer
When Trying To Scan, ScanGear Message Comes Up Saying Cannot Comminate With Printer.
Make sure the "Still Image Service" is running on your system. Right-click "My Computer", select "Manage", then open "Services" applet. Scroll down to the "Still Image Service", right-click it and set its properties to "Automatic", then right-click it and "Start" it.
Nov 08, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon mp 460
reinstall the drivers b4 u connect the printer
Jul 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Can't scan from printer or computer
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1. HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run Digital Imaging Monitor.
◄ Wait for a Minute, if the configuration screen appears it is done else refresh the HP Cue Device Discovery
◄ Restart the Printer
◄ 99% chances of resolution and in the other cases a proper uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
May 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
Compaq A3000 scan issue
The cartridges problem my be caused by the two retaining springs located under the cartridge resting area at the right side of the printer. I discovered them when I opened up an attemped to clean my A3000. Both springs were broken, an I can't tell where they were attached.
Oct 11, 2006 | Compaq A3000 All-In-One InkJet Printer
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
