Pump water level appears full and has good pressure. Went to clean pool and I found I had not enough suction with vacuum to pick dirt off bottom of pool. Filter does not need to be back washed. New sand was put in with spring start up. None of the hoses to the filter are leaking. Did notice bracket or molded form to hold down skimmer basket cover is broke. But the basket and cover remain at the bottom of skimmer. Can you advise what may be causing the problem with suction from the skimmer.
If you are getting a suction noise at the skimmer then that means you need more water in the pool. Also if you have anything in the skimmer basket like tablets then take out the basket when you are using the vac. the only other thing I can think would be the problem would be the filter is clogged. I know you have back washed it but I would do it again to be sure it is not dirty. good luck
SOURCE: NO SUCTION AFTER VACUUMING POOL
Did you use a trash plate? If not you have something stuck in the pipes and need to use an air compressor and blow from pump with main closed. Debris should shoot out!
SOURCE: no suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
SOURCE: I have a S166T90 pro series sand filter with
sounds like air in the line. Make sure vacume hose is full of water before you hook it up
