Question about Refrigerators
Is water suppose to drip onto coil in freezer area
  • 999 Answers
I assume you are hearing a drip and a hiss when it is defrosting. Yes this is a normal condition.
Eric
Posted on Jun 24, 2009
The top of the inside of my 2002 Whirlpool refrigerator Model ET1FTK (top mount)is frozen and is dripping onto the first shelf.
The cause of that drip is going to be a blocked defrost drain in the freezer and the water from the defrost is pooling up in the freezer then when it can't hold anymore it's dripping through the vent in the ceiling of the refrigerator onto the shelfs. By removing the back wall of the freezer you could find the drain on the bottom of the freezer coil. By GENTLY peircing that frozen drain at a 45 degree angle until a small hole is formed in the built up ice it could be totally flushed using warm water once a small opening is made in the ice in the drain.
GENE
Oct 13, 2011 | Refrigerators
I have a Gibson mode lRM18F6DMGA bottom mini freezer refrigerator that leaks water under the crisper drawers and eventually through the seal onto the floor. There is a ice maker in the freezer but I turned...
Sounds like a clogged drain line. Find the drain and blow or clean out the clog. Drain usually travels from the freezer coil area down to the drip pan, which is usually back bottom.
Apr 15, 2008 | Refrigerators
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
Why is my Samsung two-door fridge freezer leaking water into the bottom of the freezer compartment. What is the solution. I have defrosted it for 24 hours without success.
Hello there
You said you' ve defrosted it for 24 hours, that is good and it is the first step, Now clean out the drain system on the freezer side. The ice melts and become water it should drain out onto the drain pan underneath . But because the drain is plugged and the water can't running down the drain so it running out the drip pan onto the bottom of your freezer compartment. You may need to take out the back pannel on the freezer side to get to the drip pan below the freezing coil.
Hope this can help you to solve the problem.
Dickson
Nov 04, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Water dripping from underneath
The water is most likely coming from the condensation that's drained out of the refrigerator during the automatic defrost cycle.
Be sure the bottom fan is running and clean out the condensation tray. Warm air pulled across the condenser coils is supposed to evaporate the condensate water. If the fan is not running when the refrigerator cycles on, replace it. This would also result in the refrigerator running excessively without cycling off.
While you're working under the unit, be sure to clean off the coils too.
Good luck. Hope this was helpful.
Nov 20, 2009 | Computers & Internet
Water is leaking from inside the freezer side of
water drianage is normal, it is supposed to drip from the freezer area to a drip pan under the unit and evaporate before it gets full. check to make sure that the drip pan is properly located and exsits and that you do not have an obstruction hindering the drain opening
Aug 22, 2009 | Hotpoint Refrigerators
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
FREEZER ACCUMULATED WATER FROZEN NOW DRIPPING THRU TO FRIDGE
The drain in the freezer is blocked. Just below the cooling coils is a drain, when the defrost heater cycles on the water is suppose to go down the drain and into a pan under the ref.
Feb 13, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
