Question about GE DWSR463EGWW Electric Dryer
Change belt thr drum on dryer won;t turn
  • 351 Answers
Do you have the belt route right, on them models they have a safety switch the idler hits and if it is not activated it wont turn
Posted on Jun 24, 2009
Dryer turns on but drum won't turn
Remove the top to see if the belt is intact. If it is, you will need to replace the motor. Here is the motor to order.If the belt is broke, here is the belt to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 11, 2012 | Dryers
My dryer had a broken belt so I installed a new one. According to the directions I could find online, it said to install the belt with the smooth side against the drum. Now that the belt is installed the...
If you have the belt down in the groove on the tub it won't work. The belt slick side goes to the drum and goes back like this:
I recently worked on one of these and took photos of the repair:
http://appliancejunk.blogspot.com/2011/09/old-maytag-dryer-belt-replacement.html
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 04, 2011 | Maytag MDE308DAYW Electric Dryer
Won't tumble. Drum won't roll. How do we open it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
I HAVE A TUMBLE DRYER BECKO DRVS62W THE BELT HAS SNAPPED HOW DO I REPLACE IT. THE DRUM DOES NOT ROTATE MANUALLY IS THIS ANOTHER PROBLEM OR WILL THE DRUM ROTATE ONCE THE BELT HAS BEEN REPLACED.
If this is an electric tumble dryer,
the way to replace the belt is from the rear of the machine,
remove all the screws on the rear silver panel, which gives you access to the internals of the dryer.
And yes the drum wont turn properly if the belt is broken.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | Dryers
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Dryer power problems
Yes, all dryers have a belt that turns the drum. Chances are the belt and heat problems are 2 separate issues.. The belt turns the drum from a motor mounted inside the unit, your electric dryer has a heater element/coils that heats the drum your clothes are in. The belt could be bad and heat element also but both at exactly the same time is rare. Try unplugging the unit for about 5minutes and see if it resets. My washer does that sometimes and I have to unplug
Aug 07, 2009 | Whirlpool WED6400S Electric Dryer
GE Harmony dryer drum does not turn
open the top, pry up be careful not to chip your finish. It is hinged in the rear.
Is thr a wear spot around the drum?
It probably is belt drive
Jan 27, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
GE DWSR463EGWW Electric Dryer Logo
104 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
