Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung 46inch Slim DLP - No Power, buzzing/crackling
The TV has been randomly shutting off on me recently, however It would turn back on. Today when I got home I noticed the lights flashing on the system. So I tried to power it on. The sound I hear is not so much what I would describe as a buz, but more of an electrical crackle. It does this for a moment, then stops, then does it again, then stops, and continues untill all three lights begin to flash on the system. I took the system apart, and tried again with the guts hanging out. I notice that 2 things are happening simultaneously with the crackling sound.
1. A small piece on the ballast is illuminating and someone flickering with the sound of the crackle.
I uploaded a picture of the part im talkin about here...
http://s59.photobucket.com/albums/g318/Almostbroken/?action=view¤t=tv.jpg
2.The lamp appears to flicker faintly as well. I removed the lamp and it does not appear to have any damage to it. and doesn't appear to be burnt or have a broken filament.
The lamp has been replaced recently, within the last 5 months or so, I don't recall how long. I'm wondering if my thoughts of it being the ballast is correct here because I'd rather not waist 100$ on a replacement. Thanks in advance, any other questions just let me know.
    Genius:
  • Samsung Master
  • 1,039 Answers
The ballast board has mounted on it what is called a spark gap. When it fires the lamp it makes a crackling noise and it does light up from the spark. This is normal. If the lamp doesn't fire or won't turn on completely it will try several times. I would replace the lamp. Although if the big capacitor on the ballast board is domed on top then replace the lamp, ballast and power board at the same time. There is a serv bulletin on this but only if the capacitor is swolen. I hope this helps.
Posted on Nov 25, 2011
  • 261 Answers
Well, you definetly right...... The driver of the ballast is busted, now the ballast is to weak to maintain on that lamp. I will recommend to stop trying to turn ON tv since this could damage the bulb by blowing it from inside. I will recommend to change ballast and the old lamp should work for a little while (since I am quite sure that this bad ballast is consumming faster that lamp). Or change lamp and ballast as well that shouldnt cost you more than 200 in booth things.
you can have the ballast from samsungpartsdotcom or i also had purchase some from discount-merchantdotcom (excellent service)
Posted on Jun 24, 2009
TV just shuts off randomly. Any idea what the problem might be?
The door switch of some of these units caused that problem. see following web site: http://www.amazon.com/AA41-0756C-Switch-Sensor-SAMSUNG-HLP4663W/dp/B00NH49Y4E
May also be the lamp itself
Apr 09, 2015 | Samsung Televison & Video
Tv keeps shutting itself off. the power button will then begin flashing in green lighting the words"timer and lamp' and in red letters the word "standby". i can press the power button to turn the tv back...
The first thing to try is a new lamp. There should be an orange or red tag on the left side of your set that has the lamp number on it. The number will look something likr BP96-01434A. It probably won't be this exact number but will have that sort of format. Google "DLP lamp" and you'll find numerous sites that sell lamps. Shop around for the best price.
Sep 01, 2010 | Samsung 61" Slim-Depth DLP HDTV
We replaced the lamp on our Samsung 50" dlp model HL-S5086W tv about 3 weeks ago. Just recently, the tv started turning off by itself and the red standby/temp light and the green lamp light flash for a few...
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Jul 31, 2010 | Samsung HL-S5086W 50" HDTV
    Samsung tv turns off on its own model hls4266wx
  • Mar 12, 2010 | Samsung HLS4266 TV
    I have had this Samsung DLP HL-P 4663W for about 3 years now.
  • Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    My 56 inch hi-def projection samsung tv turns off automatically
  • Mar 06, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung HL-R6167W DLP color problem/buzzing noise
    My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
    Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
    Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
    504 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
