Question about Hamilton Beach 22505 IntelliToast 2-Slice Toaster
Hamilton Beach 22505 toaster info
The lever does not lock when pushed down anymore. How to open the toaster without breaking anything?
    New Friend:
  • 67 Answers
Usually, four screws under the bottom remove the top but the toast loader lever knob is usually press fitted on. Some units have bent tabs to hold them together if screws are not used. To remove the knob, freeze the unit (to shrink the knob/lever) then place a flat piece of wood like a ruler wrapped in cloth on the housing behind the knob and use a large bladed screwdriver to try to work the knob off. If you break it superglue and epoxy, and drawer knobs not plastic or wood might work as a replacement.
Posted on Nov 30, 2007
Manual for Hamilton beach toaster model 31144
Try Googling (Hamilton beach)(31144)(manual) without parens.
Feb 18, 2018 | Hamilton Beach Toaster Ovens
Instructions for instructions forToaster Oven - Hamilton Beach Model = 22708 H, Series A4560B1
The manual for some Hamilton Beach Toaster Ovens are available from the Hamilton Beach support site, . However, the 22708H is not currenty available. The 22708, 22708C and 22708W are available. (I also see a 22709H and 22704H).
Check your model number and then see if the manuals for the similar models are close enough to use with your toaster oven. This is the direct link for the 22708 manual: .
I hope this helps.
Apr 30, 2011 | Hamilton Beach Toaster Ovens
The toaster lever will not stay down.
mechanism or the spring may not be functioning.
Mar 21, 2011 | Hamilton Beach Kitchen Appliances - Others
Need manuel and cook book for hamilton beach toaster oven/convect
I( need a instruction manual for model # 31175 also a broiler pan
Jul 17, 2010 | Hamilton Beach 31175 Extra Large Toaster...
Handle will not stay down
It has to be adjusted through the temperature knob. You change the temperature and the main handle will get locked in down position. Just
Dec 26, 2009 | Hamilton Beach 22502 Digital 2-Slice...
My hamilton beach brewstation is leaking.
There is a spring between the lever and the o-ring. It may have popped out when you cleaned the pot. That has happened to me before. The spring is necessary to hold the seal down until the lever is pushed.
Mar 13, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Digital Display no longer showing, lever won't stay down
jsullivan22 is right about the diode. I have this problem with my 24502, which is a dual version of this. There are 2 circuit boards in your unit one with the LED display on it and another one. The diode needing replacing is on the other board. it is in the center of the board, right next to a large (1/2W or 1W) 2K ohm resistor. The diode is probably part number 3ez24d5. Test it with the diode test on your DMM, if it is bad you will get 0V both directions (I think). Also if you measure it with the Ohm function it will probably measure less than an Ohm (check the zero on your DMM as many are not accurate down this low) You can probably replace it with a <a id="ctl00_ContentMain_CartGrid_grid_ctl02_ctl00_lnkManufacturerPartNumber" href="" style="font-weight: bold;">1N5934BG</a> or a <a id="ctl00_ContentMain_CartGrid_grid_ctl03_ctl00_lnkManufacturerPartNumber" href="" style="font-weight: bold;">1N5359BG</a> Mouser stocks both of these&nbsp; (currently). I haven\'t gotten my parts so I can\'t guarantee these will work, but I\'m pretty sure. I will try the latter first as I\'m hoping it\'s higher power rating will keep it from burning out again, although I will be buying several spares. <br><br>This is clearly a design issue with these toasters and one that could be easily corrected. Both circuit boards in my toaster are very toasty in the area of these diodes, although I\'m sure the fact that these boards are mounted very close to the heating elements doesn\'t help their longevity.<br><br>Hope this helps everyone.
Sep 27, 2008 | Hamilton Beach 22502 Digital 2-Slice...
Hamilton Beach 22505 IntelliToast 2-Slice Toaster Logo
400 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
ken skalski
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
