Question about Cameras
There is no display on the LCD when in camera mode
  • d4drumsphoto Jun 24, 2009
    I ahve a JVC GR-D22 MiniDV camcorder.
    There is no dispaly in camera mode , but it will show and play a tape
  • 10,594 Answers
Please intimate exact model and brand of your digital camera that has no picture in camera mode problem to find out solution for that.
Thanks.
Posted on Jun 24, 2009
LCD works only in the stitch mode, it is dark in all other modes. Any suggestions? Thank you
Double check your display button. Cycle it thru the options to see if you are on lcd display. You may simply be in the mode where the lcd is shut off.
Dec 12, 2009 | Canon PowerShot A520 Digital Camera
How do you turn off the flash on samsung sl202
When the menu is displayed on the LCD monitor, pressing the LEFT button makes the cursor shift to the left tab. When the menu is not displayed on the LCD monitor, the LEFT button operates as the FLASH ( ) button.  Selecting the flash mode 1. Select a desired Recording mode, except the [Movie] mode and the [DIS] mode. 2. Press the Flash button until the desired flash mode is displayed on the LCD monitor 4268flashicon.jpg The flash does not fire. Select this mode when capturing images in a place or situation where flash photography is prohibited. When you capture an image in poorly lit conditions, the camera shake warning indicator ( ã ) will appear on the LCD monitor.
Oct 24, 2009 | Samsung SL202 Digital Camera
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
Sony w200(12.1MP) Shoot Mode no display
I was having the same problem earlier and I showed my camera to my father and he fixed it! What you need to do is press the center button (that usually toggles between viewfinder mode and LCD mode) and when the display is on (mine would come on for a second or two and then go black) press the up arrow (the display button). Now the display stays on during shooting mode! This fixed the problem for me and I hope it helps you out too!
Jan 16, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Black spot in display
If the camera operates normally and the only problem is no picture is visible on the lcd in record mode and playback mode,then the lcd needs to be replaced.
Jul 31, 2008 | Casio Exilim EXZ1050 Digital Camera
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
Flash
the left tab.
■ When the menu is not displayed on the LCD
( ) button.
● Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING
mode with the exception of MOVIE CLIP mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
LCD monitor and electronic viewfinder
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
LCD Monitor on and the electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
Cameras Logo
51 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
