2004 Mazda tribute steering wheel squeaking
Well a steering flush would not necessarily be related to squeaking.
So, you need to locate exactly where the sound is coming from...
It really sounds like steering wheel turning and resistance causes the noise, is this constant, or only while actually turning the wheel?
Likely it would be semi constant, so that would focus you on the assist portion... Be careful around all moving parts, but you need to locate the source.
Try taking a section of heater hose, and listen through one end and move carefully around with the other end and see what you find. Likely something under the hood, with your note about window open...
Now, if the squeaking stops when the steering wheel stops turning, now steering components are suspect.... So, again, louder with window down makes me think outside and in front...I would stand in front of the car, have your handy assistant actuate the steering wheel, and you decide which side, right or left.... Suspect items that squeak only during steering wheel input include, amongst other things, the entire strut, all ball joint, including joints in the steering linkage.... Be sure to keep clear of moving parts, your handy assistant would not know they they are crushing you, while truning the wheel......
Doc
