Question about Sharp AL-1641CS Laser Digital Copier
Tried to clean the rollers
I tried to clean rollers or feeders that are visible to me. I don't want to explore further for fear of wrecking something. Which part of the machine is it that I have to clean? Because in my case, the spots are random but seems to be in the same spot in every other pages or so. Please help. Thanks
    New Friend:
  • 91 Answers
If the spot appears in the same exact location, you should clean the copy glass but if the spots are in the random area at the same line you should check the drum seal of the drum unit. The seal purpose is to prevent the waste toner from spilling to the drum and copy paper
Posted on Jun 25, 2009
Sharp ar5316 will not load paper from feeder tray or something it grabs it but does not go round the rollers for printing... any idea what the issue is..
i think youre problem is youre clouth casset paper
you have to open back cover
2- close dricer
3- close cloth
4- service cloth
Apr 21, 2017 | Sharp Office Equipment & Supplies
How do you clean rollers on manual feeder
To clean the rollers or separator pad
1. Remove all originals from the document feeder tray.
2. Lift the automatic document feeder cover (1).
This provides easy access to the rollers (2) and separator pad (3), as shown below.
1 Automatic document feeder cover
2 Rollers
3 Separator pad
3. Lightly dampen a clean lint-free cloth with distilled water, then squeeze any excess
liquid from the cloth.
4. Use the damp cloth to wipe any residue off the rollers or separator pad.
NOTE: If the residue does not come off using distilled water, try using
isopropyl (rubbing) alcohol.
5. Close the cover of the automatic document feeder.8_29_2012_4_02_48_pm.jpg
Aug 29, 2012 | Dell 1135n AllInOne Laser Printer
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
The feeder of my dell 948 printer crushes the paper and it does not go straight through the feeder (it is pulled to the leftside). Searchin on the internet I found a solution for if something was stick...
Use alcohol and a swab to clean off the paper dust off the pickup roller. You can also get paper path cleaning sheets from office supply stores. They are sticky on both sides and will remove paper dust from the rollers in the paper path.
May 04, 2017 | Office Equipment & Supplies
I have " HP
Hi there !
If you have problem with roller feeder and not feeding the paper properly, just try to clean the roller feeder using clean cloth with water and cotton swab with water. Maybe there are too much dirt into the roller.
Also, use you finger to roll over the rollers that might stuck up. Because something it stuck up and need a little push on it.
I hope it helps you.
Jan 21, 2011 | Office Equipment & Supplies
Red/yellow line down left side of document when using feeder
the solution to this issue is cleaning the scanner glass below the automatic document feeder(mind you its not the scan bed that you normally use while copying) .you will get the ADF scnner glass once you lift the ADF door,you will see a 1 inch wide scanner glass.that is what you need to clean.
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Jun 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Paper feeder
clean the rubber roller with alcohol this roller gets dirty all the time...this feeds the paper...im trying to upload my drawing..to guide you..
Feb 09, 2008 | Canon S520 InkJet Photo Printer
Sharp AL-1641CS Laser Digital Copier Logo
75 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
