Question about HP OfficeJet 7110 All-In-One Thermal Printer
HP OfficeJet 7110xi
Every scan or two (or fax out) the scanner will give the "Scanner Failure: Please turn off and back on the printer" error on its screen. I've checked the internal cabling to ensure it is plugged in securely, the power is from a reliable source, and I have done the semi-full reset and gone through all the instructions per http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en&product=91475
Any final ideas? It seems to work fine until it gives that error, and upon restarting it, it works fine again. This happens regardless of machine it is attatched to.
    Scholar:
  • 169 Answers
Finally you can try a reset on the macj\hine using the # and the number 6 buttons(holding them down and then plugging in the power cord at the back of the machine).If it still gives the same error..try the same with the # and 9...same problem comes up....service the printer
Posted on Jun 24, 2009
Says scanner failure, scan, copy and fax will not work, did the print alignment still not working Only the printer works
try use a high quality usb cable, some usb cables has low bandwith, and give some strange, errors like scanner error, copy,...
Feb 09, 2010 | HP Officejet J5780 All-In-One InkJet...
Scanner failure-no longer prints
Hi, I'll give your situation a "stab in the dark" solution. It sounds like you are in the final stages of "scanner system failure". The beginning stages usually limits the all-n-1 to print only i.e., no scan and no fax but you may have such a severe scanner bulb situation that is preventing the print function and may be causing hazardous conditions within your printer and it will do nothing to prevent further harm or damage. Can you describe your situation a bit more detailed?
Apr 16, 2009 | HP Officejet 5610 All-In-One InkJet...
SCANNING FAILURE ON HP OFFICEJET D135
Bad SCANNER UNIT. Uneconomical to repair. Sorry
Jan 30, 2009 | HP OfficeJet D135 All-In-One InkJet...
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Apr 25, 2008 | HP OfficeJet k60xi InkJet Printer
Scanner Failure: HP Officejet 6210
After hours of trying things.I found this and it worked. The scanner button doesn't work, but at least I can scan.
?id=microsoft.windows.resources.expandarrow To scan a picture using Windows Photo Gallery
    Before you begin, make sure that you've installed your scanner on the computer and that the scanner is turned on.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Windows Photo Gallery.
  2. Click File, and then click Import from Camera or Scanner.
  3. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
Jan 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 7130 "Scanner Failure"
Scanner failure usually means you'll have to replace the entire scanner unit.
When the machine turns on (or gets plugged in), does anything happen...any lights come on?
Is the machine able to print from the computer and recieve faxes while the scanner error is present?  If so, you probably need a scan unit.
Oct 29, 2007 | HP Officejet 7130 All-In-One InkJet...
Scanner failure
scanner failure, turn unit off and back on, does not help
Oct 01, 2007 | HP OfficeJet d145 InkJet Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
186 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
