Question about GE Dishwashers
Wet floor lower left corner - GE Dishwashers
  • 6,784 Answers
Check the drainage house. its located in that area under the unit. it may have slipped off the housing. if the drainage hose is OK, replace the water valve assembly.
Posted on Jun 24, 2009
Only when driven in rain my floorboards become soaking wet , what causes this?
Can be three things
a hole in the floor pan, look in the front corners left and right side especially left side wheel arch.
a rubber grommet that has perished where one of the controls goes through the firewall between engine and passenger compartment.
faulty gasket and sealant around the windshield
Mar 10, 2016 | Cars & Trucks
How can I adjust an upright freezer door ?
Hello there,
It is always the feet and their adjustment and floor must be level
From the user guide it says
;The freezer must have all bottom corners resting firmly on
a solid floor. The floor must be strong enough to support
a fully loaded freezer.
NOTE:It is VERY MPORTANT for your freezer to be level in order to function properly. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems.
To level Upright Models:
After discarding crating screws and wood base, use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, half a bubble higher, so that the door closes easily when left halfway open. ;
User guide here
http://crosley.com/assets/product/1707/useCareGuide.pdf
Sep 24, 2014 | Crosley CFUM21LW 20.6 cu. ft. Upright...
I have several large water spots on the lower right corner of the tv from overspray with windex. Can this be fixed?
Not a good idea to clean tv with windex. Try wet towel dipped in mild soap solution. Make sure all water has been removed and towel is only wet. When tv off, try removing the spots. Turn tv on only after tv dry.
Dec 22, 2013 | Apex Digital LD4088 LCD TV
How do you level the refridge side to side?
Hi, normally, the units have a screw in type foot at each corner to level the unit. To raise a corner you would turn the round like foot CW. You may need to push on the corner you are working on to relieve pressure and also use a pair of pliers or channel lock pliers to turn them, but this is how it is done. Just remember, to raise you turn it CW which puts pressure on the floor and CCW to lower it, it will screw back into the box. To raise the right side you will go CW screw out and to lower left side go CCW screw in to lower.
Sincerely,
Shastalaker7
Jun 30, 2010 | Samsung RF265AA Bottom Freezer French Door...
Car mat on pasengers side is soaking wet is the drain off pipe blocked which is making the floor wet.
your drain plug under the floor is a rubber plug and it could have came out, to look for it look under your car on pass. side floor board and check to see if the plug fell out. Also this happens when the seel on the lower corner of the winsheild is not seeled or is missing some of the windsheild caulk in that corner. This happened to my car and it was the corner of the windsheild causing the problem. Hope this helps you and good luck.
Feb 27, 2010 | 2000 BMW Z3
Leaking from left corner GLD2250rd Frigidaire dishwasher
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Water leak front left corner of freezer.
Your defrost drain line in the freezer is frozen closed.
You must turn off the fridge.
Remove the visible ice.
Use a hair dryer at the drain opening in the lower back of the freezer to melt the drain line ice.
Mar 11, 2009 | Electrolux Refrigerators
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
