Question about E-Machines M5105 Notebook
Cannot shut off & no display
Power and Battery lites on, cooling fan cycles-air is hot, Hard drive is running but not "working" on anything, no display. No response from power button when held down, nor "sleep" button. Cannot shut off unless I remove battery and ac in.----tried the solution of f3 with battery out, still no wake-up..... Re-seated mem chip, tried external display, re-seated HDD and left without power for 1 hr. - same old result.
    Problem Solver:
  • 7 Answers
The eMachines M5105 is notorious for failing to boot if left unplugged and powered off long enough for the battery to become mostly discharged. Plugging it in to AC power will cause the battery to start charging; and the hard disk drive to spin while the CPU cooling fan cycles on and off vigorously. THE UNIT WILL NOT BOOT UNTIL THE BATTERY IS NEAR FULLY CHARGED; then THE AC DISCONNECTED; and then THE (charged) BATTERY REMOVED AND RE-INSTALLED! Most units will boot after following the foregoing procedure.
Posted on Jan 17, 2012
2 Suggested Answers
  • 1087 Answers
SOURCE: should the sleep led be lite blue while notebook
There is a setting in some bios's for the sleep option. You may want to look in there to see if its active.
Posted on Aug 14, 2010
Why isMy Acer aspire gettting really hot, would replacing the battery help?
Sometimes, the computer gets really hot because the "ventilation" (cooling) system (fan, etc.) is not working properly. Normally, if it gets too hot, i.e. to an unacceptable level, the system will shut down. Or, it will catch on fire.
Yes, it's known that some battery will get too hot ... and potentially damage the system. So, if you already know that the cooling system is working properly, then try replacing the battery.
May 28, 2014 | Acer Aspire One PC Notebook
Trane xr12 blower stays on after first cool cycle run
Hello, this is usually caused by a sticking fan relay on the intergrated comtrol board. You may be able to tap on it to shut it off but eventually the control board will need to be replaced.
Jun 02, 2012 | Heating & Cooling
It keeps shutting itself off ?
When does it shut itself off? Is this happening time you press the power button and during the boot cycle it shuts off without completing the boot to windows? If it shuts down after you've worked on it for a while it could be that it is running hot. If you let it sit a while to cool off then press the power button, if it completes the boot cycle and allows you to work it is definitely running hot. Normally when they run hot if you immediately try to reboot, it will fail. If you let it cool off it will boot successfully. Computers run hot because of a fan not working, dust clogging the fan vents or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep the unit cool. If it's not running hot you might have a power supply or motherboard issue. Try removing the power cord and press and hold the Power Button for 30 seconds to release any Static Buildup. Then plug the power cord back in and try to reboot.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
My 2000 hyundai elantra is overheating..when i turn the ac on only one fan comes on the other doesnt
COOLING FANS NOT RUNNING
It is normal for the A/C air to warm up a little when stopped. Less airflow thru the condensor. It is normal for the engine temperature gage to rise up to about the 80% mark on its scale before the cooling fan kicks on. The gage will also show about the same reading on the first start of the day, until the thermostat opens.
If the fan(s) are not working properly the A/C air and engine temperature will rise. If you have a belt driven clutch fan, the clutch may be worn out. All cooling fans kinda sound like miniature jet engines when its hot out, more so when the A/C is on. Replacing the clutch is all you can do for a belt driven fan. Electric fans are more complicated....
Check all main power electrical connections first.... Electric Fan(s) not working, Checking the fan(s), relay, fuse and engine temperature sensor's.
Verify that the fans work by unplugging them and run jumper wires to the fan(s) from the battery. If they run, your problem lies elsewhere. If either does not run, it's the motor.
Next thing to check is for power at the fan connectors. You have to be cautious doing this because the engine needs to be running and warm if not almost hot, and the A/C also needs to be on. (Both must be on and running for the duration of this checklist.) The A/C fan is on the passenger side and should come on almost the instant the A/C is turned on. It is also the secondary engine cooling fan and should cycle on and off in relation to engine temperature. Use a test light to probe the two wires on each fan. If you find power the fan motor(s) is/are probably bad. If there is no power to fans, roll up your sleeves!
The temperature switch is usually located above the oil filter. If the dash gage is working, its probably OK. Next is the Fan Control Temperature Sensor, located IN or CLOSE to the thermostat housing. You will find out if it is working later is this checklist. I just wanted you to know where it is. Next is the relays and fuse's. Usually located in the engine compartment on the passenger side power distribution box. You will need to remove anything over the cover to open it. If the fuses are OK, tap on the relays or pull them out and push back in. If the fans are still not running, pull a relay and probe the socket terminals for power. Two or three of the terminals should have power, usually criss-cross from each other. Two are hot battery power, and the third is the "signal" voltage which triggers the relay to send 12V battery power to the fan. This signal voltage comes from the sensor at the thermostat. If only two terminal's have power, then I would replace the thermostat sensor if not both sensors.
Hope this is clear as mud! and helps! Please let me know what you find.
Aug 27, 2011 | 2000 Hyundai Elantra
Air conditioning starts to blow cold, then it blows hot, turn blower motor switch off and on and then it will start to blow cold all over again and then blows hot air. they replaced the orfix and...
Sounds like the secondary engine / A/C cooling fan is not running.... Fine on highway is due to more airflow across the condenser...
You didn't mention the year or model so this will be generic. The temperature switch is usually located above the oil filter. If the dash gage is working, its probably OK. Next is the Fan Control Temperature Sensor, located IN or CLOSE to the thermostat housing. You will find out if it is working later is this checklist. I just wanted you to know where it is. Next is the relays and fuse's. Usually located in the engine compartment on the passenger side power distribution box. You will need to remove anything over the cover to open it. If the fuses are OK, tap on the relays or pull them out and push back in. If the fans are still not running, pull a relay and probe the socket terminals for power. Two of the terminals should have power, usually criss-cross from each other. One hot terminal is battery power, and the other is the "signal" voltage which triggers the relay to send 12V battery power to the fan. This signal voltage comes from the sensor at the thermostat. If only one terminal has power, then I would replace the thermostat sensor if not both.
Aug 20, 2011 | Chevrolet HHR Cars & Trucks
My compaq problem is that it runs hot and shut off every time
try cleaning your computer of dust using a fine air blower from a compressor making sure that there is no?MOISTURE in the air line dust causes static to build up in a computer causing it to overheat any many other problems
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 15, 2010 | Compaq Presario Fan
Vaio VGN-CR35 laptop not booting at all. When started, screen is blank and power led turns on, num/scroll/caps keys flashes once, battery and hard disk led turns on once and immediately goes to off....
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 13, 2010 | Sony VAIO VGN-CR220E/P Notebook
Running very hot and shutting down
You are running into a CPU overheat issue.
1. can you feel or hear the cooling fan come on at all? If so try and use compressed air can to clean it out.. they get tremendously dirty. You can also try a vacuum hose, but cover nozzle with hand and only hold next to cooling fan outlet and nowehre else with laptop off and unplugged. Dont get near keys or other parts as will damage. Dont use SHOP VAC either.
2. If Cooling fan is NOT Coming on you can try a laptop cooling pad. these are external units by Targus and other companies that have cooling fans to supplement a laptop units cooling fan. You can try this to see if airflow is your problem.
3. If you recently ran encryption software, a new antivirus program, or upgraded to Windows 7 it is possible that your culprit is the unit is not cycling. Meaning the hard drive is continuously being accessed and the CPU is in constant service... this can cause overheating as well.
Jun 02, 2010 | Toshiba Satellite A135-S2276 Notebook
Fan motor runs for awhile and then runs hot and shuts off
Bearings in the motor may need oiling. look for a tiny funnel hole on a tube on the ends to oil it. Remove power first.
If none it could be permanently sealed and need to replace the motor.
Let it cool before touching anything. again remove power first.
Jul 06, 2009 | Heating & Cooling
E-Machines M5105 Notebook Logo
148 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
