Question about Dell Inspiron 700M Notebook
No sound unless i close the screen down a little.
My Dell 700m screen got hit by friend's kid yesterday, and after that there is no sound come out from the computer. If I closed the screen down half way, then the sound is coming out. How can I fix this problem? Thanks.
  • Rassy Dec 18, 2007
    Thanks for your site. My headphone worked on my Dell Inspiron 700m but not the speakers. When I saw this column I partially closed the screen (where the speakers are located) and voila! Sound! No kid touched my computer. What a bizarre problem!
Ok, the real solution to this problem is that the wires for the speakers run through the right side hinge, when the screen opens and closes many times (twisting and untwisting the wires) the wires break.....solution is to disassemble the screen shroud and hinge, and run new more flexible wires through the hinges. clearances are tight and the painted panels on the 700m scratch easily, but it can be done. If you have the speakers replaced the same brittle wires will be put in and they will inevitably break after a year or so anyway.....good luck
Posted on Feb 20, 2008
The first thing you needed to tell us is if the speakers are located in the screen or the body of your laptop.
You don't give specific enough behavior on the system accident. Did the kid slug the screen with his fist, or did someone bounce a baseball of a vase off it... Did he slap it closed.... Was the screen or the case the point of impact?
Test your audio hardware with a music CD, and headphones. IF it works then you've eliminated some possibl shorts. If you get uninteruptible sound in a head-set, then it's likely the connection to the speakers that's shorting.
Likley as not, it is one of 2 things. Since you get any sound at all suggests that there is either a transient short to the pouwer supply or a transient short from the audio port to the speaker.
Transient, as it was described to me, is simply a short which causes the componant to sometimes work, or to sometimes NOT work. I am as serious as a heart attack when I tell you my buddy has a woman's virator in his tool box, so he can prove if a part had a transient sort by introducing a safe, high density "micro" shake to the part. That causes the componant to exhibit in a rhythmic but sporadic failure. Then you start looking for the two places that might be at. The 2 major places are always your supply, and between whatever directly provides output to the module in question.
As long as you DON''T puncture the screen, and you DO stick to places where there could be shorted wires, you should be okay.
This is what I would do.
1) I'd put a CD into the computer, then I'd check my audio software to make sure it was playing.
2)Whether or not I got sound I would try to reproduce the fault.
IF the fault occurs in headphones then the short is between your CD drive and whichever parts or wires cconvey the current INTO the board or into the port
If the fault only occurs in the speakers go to step 3
3) Turn the vibrator on and place the business against the case part of the laptop screen. If the fault is in the speakers then it is probably the connection to the speaker.
. If the short is in there, you'll have to take the screen apart and carefully look for a short circuit there. A transient short is most likely caused by a sharp blow, and in places where you have wiring soldered to a denser frame work, or lighter gauged wire, the heavier of te two is "thrown" harder and will separate from the solder joint.
If the fault isn't there put the vibrator the the keyboard casing and see if it happens there.
If it happens there, you have to check the physical ports involved (in the audio modual) in question, from port to speaker, from CD player to port or sound card.
Posted on Nov 05, 2007
  • KelleyJ Nov 05, 2007
    BTW. The good news is that you can fix most transient shorts, sometimes reconnecting places where speakers have come unplugged. IF you have equipment, you can resolder wires back to boards, BUT ONLY IF YOU ARE SURE, BEYOND THE DOUBT OF A REASONABLE MAN, OR ACOMPLETE LUDDITE; (no, silly, I mean that a luddite couldn't miss the fault THE SOLDER POINT WAS SO OBVIOUS!)
    The bad news is that if you can't find the fault, then you pay a per hour rate to someone who can find and fix it.
    If the short is caused by a broken part which must be soldered to the motherboard, it may be advisable to let someone who has a soldering iron that small (a very steady hand) do the work for you. If you short the motherboard you'll end up with an expensive motherboard, and if *I* were to pay that much for a paperweight, it better be blown glass, with precious metals torched in.
Dell inspiron 700m no sound
You may have the well known issue just as I had which is the lines running up the left side from keyboard to screen which are supposed to go to the speakers easily break because they are very small and they break from just the opening and closing of the screen. It's no worry I dug it all out and still just went on Amazon and got a USB audio speaker/headphone interface for $8.
Here's what I got and I am very will save a lot of time to just grab this now... Trust me. I would never suggest if I didn't like it and have used or owned it.
Jun 14, 2014 | Dell Inspiron 700M Notebook
My laptop doesn't produce any sounds not untili close it halfway if i have the screen open totally no sounds. how do i fix that??
Well, it "sounds" like your speaker wires are either crimping or loose at a connection, you will need to remove the screen assembly to inspect further. Go here!
Sep 04, 2012 | Dell Inspiron 700M Notebook
While trying to get on the internet from my Dell Inspiron laptop, i keep getting a message that the wireless is turned off. I press the F2 key, which shows 2 towers - one with sound waves coming out and...
on the bottom right hand of your screen where it shows the time and then a bunch of little icons, there should be one for internet connections, probably looks like two computers, maybe with screens blinking. right click that and then click on whatever it say: manage network connections, maybe configure something. then you should be able to controll everything from turning on and off wireless and selecting which network you want to join.
Jun 21, 2011 | Dell Inspiron 700M Notebook
I have a dell inspiron 700m willnot display
Hi There,
The best way to begin the troubleshooting process for your problem is to connect your laptop to an external monitor. If you don't have one at home I hope you can ask a friend to allow your to use theirs for a few minutes.
With the laptop off, and the monitor off, connect your laptop to the external monitor. Next turn on the monitor. Finally, turn on your laptop and on one of the F keys in the row of keys above the regular keyboard letters should be one key that either shows what looks like a little monitor screen/screens or as on most Dells, one key will say CRT on it and it's usually the F8 key.
Hold down the fn key in the lower left hand corner and hit the F key as described above that's assigned to make you switch from the laptop screen to the external monitor.
If the monitor ahows what you'd normally see on your laptop screen, then you know that your laptop screen has worn out and needs to be replaced. If both screens are black then your problem is much more serious and the odds are greatest that your video card/controller on the motherboard has failed. For most laptop repair guys this means replacing the entire motherboard.
I sincerely hope the problem is the first one because it's the least expensive. If not, I'm sorry to be the bearer of bad news, but then you at least know the truth of your situation. Also, a favor? If the worst case scenario, remember I didn't do it (grin) so please don't thrash my reating. I'm a professional laptop repair specialist just trying to lend a hand.
Best of luck to you.
Sep 07, 2010 | Dell Inspiron 700M Notebook
Dell Inspiron 700m won't start
It sounds like there is an issue with the system memory.
Remove both the power adapter and the battery. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
If it still won't boot up then you may need to purchase new memory for the laptop.
Good luck.
Sep 28, 2009 | Dell Inspiron 700M Notebook
Dell inspiron 700m - turned off and i needed to restart it
It sounds more like the machine is overheating slightly. I would take it to a repair shop and ask them to check it out.
Jun 07, 2009 | Dell Inspiron 700M Notebook
No sound from internal speakers on Dell Inspiron 700m ?? Any Ideas. I ahve atried all the basic stuff
sometimes the wires for the speakers break... just take the laptops panel above the keyboard out, remove keyboard, unplug the 4 white and black wires, and repair the break... Takes about 10 minutes to do! and you'll get your sound back.. Dell had a small design flaw there, but you'll get the speakers running easily! Same thing happened to my Inspiron 700M..... You can splice the wires and fix it yourself!
Jan 03, 2009 | Dell Inspiron 700M Notebook
Dell Inspiron 700m
sounds like your SYSTEM32 Folder corupt, do a system restore.
Dec 20, 2008 | Dell Inspiron 700M Notebook
Blank screen
the power is supposed to stay on when that little plastic button is pressed(screen switch)the screen switch activates hibernate and power saving;if you press the power button a screen will open informing you what programs are currently shutting down you have caused an illegal command.
hopefully if you restart in safemode then shut down correctly and restart every thing should be ok.
Mar 03, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 700m screen acting up
try to uninstall and install the the display drivers / graphics card drivers.. it should help you.
Feb 20, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 700M Notebook Logo
290 people viewed this question
Alun Cox
