Question about HP PhotoSmart C5150 All-In-One InkJet Printer
I have a HP Photosmart C5150 printer. It says it can't print, to replace the yellow ink cartridge. I have replaced the cartridge twice but I still can't get the printer to print and it is still displaying the same "Replace Yellow Ink Cartridge " message.
    President:
  • HP Master
  • 1,996 Answers
Please see this link. It's a bit unorthodox as a solution, but if you've already worked through the cleaning options available at hp here, it's worth a try. Certainly cheaper than buying new cartridges that don't work.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 24, 2009
Photosmart D7360 - message says "ink cartridge empty. To print in color, install the following cartridges: yellow. To print in black ink only, press o.k." I have replaced the cartridge (yellow) and the...
go to hp support>d 7360 >software and drivers. Download (run) latest diagnostic utility 2010-11-09. run test and print test page (only one sentence). worked for me. Took about one minute.
Sep 10, 2010 | HP Photosmart D7360 All-In-One InkJet...
Ink system failure error telling me to refer to printer documentation error 0xc18a006
The "Ink system failure" error is caused by air in the ink feed tubes, this happens if you use poorly filled cartridges or allow you cartridge to run all the way out. We have a step by step guide to purge the ink feed tubes posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This should get your printer back going in about 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 02, 2010 | HP Photosmart C6100 All-In-One Printer
Ink and Print issues always says replace blk and yellow ink and printer says its ready to print but won't print on HP Photosmart C6180
If you have replaced them and it still says so than it is not reading the chip on the back of the cartridge. push and wiggle the cartridge and see if there is a change. If you do a lot of printing and are tired of getting screwed by HP look at the refillable carts on this page "http://www.inksupply.com/inkjet_cartridges.cfm?search_getmodel=982" . Just never use any other brand of ink. cheap ink will kill the printer.
Sep 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error message: ink device failure oxc18a0506
Perform the following on your printer http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jun 18, 2009 | HP PhotoSmart C5150 All-In-One InkJet...
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Yellow ink cartridge will not print
The print heads must be bad. I had the same problem. Still under warranty and HP replaced printer with rebuilt unit
Feb 23, 2009 | HP Photosmart D7160 InkJet Printer
New Cartridge error message
Did you check to make sure there is nothing covering the cartridge? I know that sounds dumb but that is what happened to me-I had mine refilled and it would not work and when I took it back in they said well-you just take this off here-it was a tiny piece of tape that was almost invisible!
Jan 25, 2009 | HP PhotoSmart C5150 All-In-One InkJet...
HP C5180 yellow cartridge empty
Thanks for everyone for posting there problem with HP C5180 with the yellow ink being empty. With out this I would not figure and made attempt to fix it.
Credit to Longtimemacuser @ http://h30434.www3.hp.com/psg/board/print?board.id=Printing&message.id=525&page=1&format=page
Same here-  I'm running into this problem for the second time in less than 3 weeks on my HP C5150. . Brand new cartridge installed, and it is fine for a day - then 2 days later, after NO color printing - it suddenly shows as completely empty.
Last month when I had the same problem, customer support suggested the following, which seemed to work.
(typos were theirs - I just copied and pasted):
Please try the following step's
Power your C5150 on and remove all 6 cartridges and close the cartridge access door
With your C5150 powered on unplug the power cord directly from the back
Press and hold the OK button and the HELP button down together while you plug the power cord back in
Keep the button's held down until the display screen goes blank then release the button's and power your C5150 back on
When you are prompted on the display screen to install the cartridges install all 6 cartridges and close the cartridge access door
Are you still getting the same message ?
I did the printer reset but I only removed the yellow cartridge. follow the on-screen prompt and this process will take about 3-5 minutes. When everythings done, suggest to clean the printer head
Hope this help
Anthony L.
This should resolve the issue. If you need further assistance, please reply to this message and we will be happy to assist you further.
You may receive an e-mail survey regarding your e-mail support experience. We would appreciate your feedback.
For information on keeping your HP and Compaq products up and running, please visit our Web site
at:
http://www.hp.com/go/totalcare
Nov 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP PhotoSmart C5150 All-In-One InkJet Printer Logo
287 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
