Question about One For All URC-3021 Remote Control
20 inch magnavox tv
I need to program my urs 2021 one for all for the tv.
  • 259 Answers
Magnavox 0054, 0706, 0030, 1454, 1254
Symphonic 0180, 0171
Emerson 0479, 1479, 1278
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
Posted on Dec 12, 2007
Ur5u-8780l not operating channels on Magnavox TV. Tried all codes and switched channel control to TV, still nothing.
If you are using a universal do not expect it to even if it programs to have all the functions you need or want or had with the original remote.
Universal remotes are far from UNIVERSAL.
The best argument for an original remote is even if it programs it will just not have all the features needed or wanted that the original had.
Hope this clears things up a little.
Apr 03, 2012 | Televison & Video
I have a realistic pro-2021 scanner and dont know how to operate it other than turning it on or off can you help ??
Programming Frequencies
1. Select the desired channel.
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency.
4. Press [ENTER].
Selecting the Channel
Step 1:
1. Press [MANUAL]. Continue pressing until the display shows
Channel 20. Press [PROGRAM].
2. Press [2][0][MANUAL]. Press [PROGRAM]. (or press [PROGRAM],
press [2][0], press [PROGRAM]).
Step 2:
Press the keys (example 162.55)
Step 3:
Press [ENTER]. To program the next frequency, move to another channel in
this way. Press [PROGRAM] to advance to the next channel. Repeat the
same steps to add more frequencies.
1. Turn the power on.
2. Press the number key that corresponds to the bank to be skipped.
3. The corresponding bank number indicator disappears from the display
and the entire bank is skipped.
NOTE: To restore the banks, press the number key again.
To search for transmission, press [PROGRAM], enter limits of frequency
range, and press [up arrow] or [down arrow] to activate "search."
1. Press [PROGRAM].
2. Press [LIMIT].
3. Enter the lower limit of frequency range to be searched.
4. Press [ENTER].
5. Press [LIMIT].
6. Enter the upper limit of frequency range to be searched.
7. Press [ENTER].
Activate "search" by pressing [up arrow] or [down arrow]. [Down arrow]
starts search from the highest frequency and goes down. [Up arrow] moves
in the opposite direction.
Press [SPEED] to accelerate or to slow down the search.
Jan 07, 2010 | Radio Shack Pro-2096 Base Scanner
Trying to program Philco URC-2070 remote control
I determined that the Philco Remote Control that I wanted to program for use on a Magnavox tv was too old (20+ Years) and dead. It also did not have the features of a new Universal Remote. So, I tosed the Philco remote and purchased a new Universal Remote Control.
Thanke you..
Mar 19, 2009 | Philips Magnavox 20MT1336 20" TV
Need to program a universal remote but cant turn on tv
take ur tv to a local tv repairman, they will have a magnavox remote. use it and simultaneously press tv/av and enter
Dec 14, 2008 | Philips Magnavox 27MS343S 27" TV
I have a problem with my Magnavox 20ms3442/17B
hi . have u increase ur colour setting ? check for ur tv regional system setting may be pal i or bg or secam & set it to ur regional standard.
Nov 04, 2008 | Philips Magnavox 20MS3442 20" TV
Programing my remote?
you should be able to hold down the desired function you want to program......(for tv, hold tv) since i dont know what tv brand your trying to get it to work with i can only suggest holding down the tv button after you turn on your tv manually and hit the channel up button until it changes the channel. turn of the tv with the remote and see if it turns it back on. if it works you should be good to go. hope this helps
Jan 01, 2008 | RCA RCR460 Remote Control
Need the code for my remote
codes for magnavox tvs: 0054, 0030, 0179, 1254, 1454
the programming procedure is as follows:
1) turn on tv
2) on the remote, press "tv"
3) press and hold set until the led blinks twice, release set
4) enter the 4 digit code, light should blink twice
5) aim remote at the tv and press power, the tv should turn off
6) if it doesnt, repeat steps 2-5 with the next code on the list
hope this helps
Nov 17, 2007 | Televison & Video
One For All URC-3021 Remote Control Logo
44 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
