Question about LG LRBN20510WW Bottom Freezer Refrigerator
LG fridge/freezer rumbling/vibrating sound
Freezer is making the same vibrating sound, but stops when the door is open? There is a lg. build up of ice on back wall. Thoughts?
  • chrisrej Jun 24, 2009
    Thanks- Now, another question. Should I try the hair dryer to get rid of the ice build up. It is my mom's fridge, she passed away and we can find no manuals. Just trying to avoid a repairman!
  • 999 Answers
Check your defrost components. The fan is hitting the frost buildup and will shut off when the door is opened so as to not circulate the warm air. The heater or the timer is not doing a proper defrost cycle.
Eric
Posted on Jun 24, 2009
  • Eric Duda
    Eric Duda Jun 24, 2009
    There is buildup behind the back panel also. Hairdryer will work, but it will only be temporary until you get the defrost circuit working again.Sorry to hear of your loss. Eric
  • Eric Duda
    Manual here:
    http://www.managemyhome.com/mmh/lis_pdf/...
    Eric
Fixed in my unit by changing the motor of the small ventilation fan. It's located behind the freezer drawer. Not expensive (around 30$) but a bit tough to reach.
Posted on Mar 05, 2010
Ice build up in LG frost free american freezer
You have a problem with your auto defrost system or someone did not get door shut all the way
Jul 14, 2014 | LG Refrigerators
LG 262SQA Model fridge cannot cool
That does not look like an LG model number, but regardless, it sounds like the defrost system is not working, allowing frost to build up and block air flow over the cooling coils in the freezer (where all the cooling for the entire refrigerator takes place). Take back panel off inside freezer, melt frost / ice with a hair blower. Test for continuity through defrost heater and replace if "open". If it was OK, problem could be deftost control, or as simple as a door not fully closed at some time, allowing excessive frost build up.
Nov 18, 2011 | LG Refrigerators
When doors are opened it stops. Ice is forming unnaturally in the
It sounds like you may have a bad evaporator fan motor or broken blade.
Another cause could be a failed defrost system component. The would cause a build up of ice and frost and the fan blade could be coming in contact with the frost or ice.
The fan stops running when the doors are opened on this model to prevent the circulation of warm air.
Sep 11, 2009 | Bosch Refrigerators
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
Lg fridge freezer model gr-s352gca fault
Buy another brand. LG are cheap and nasty when it comes to whitegoods even though the price tag is still up there. I have done nothing but research for my next fridge and i might go with the same brand as i have had for the past ten years and have not had a single problem.(it is definately not a LG of Samsung or one of these other brands that have all the advertising and have only been around for a little while)
Jun 01, 2008 | Refrigerators
Problem with GL-T 242 QM LG Fridge
Pull out the freezer and ckeck for ice build up on the back. Unplug and defrost the freezer for 3-4 hours - leave the freezer door open. There may be ice covering the vents to the fridge.
Apr 28, 2008 | LG LRBN22514ST Bottom Freezer Refrigerator
Lg electro cool fridge
hi mine was doing the same we recently movedhouse you need to turn the legs in front underneath so the fridge freezer is slanting so that when you open the door it will shut on its own now i have no water or ice build up on the bottom hope this helps.
Apr 08, 2008 | LG Refrigerators
Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Mar 09, 2008 | Refrigerators
LG LRBN20510WW Bottom Freezer Refrigerator Logo
1,355 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
