Question about Toro Lawn Mower With Toro Power Tools
Lawn mowewr wont restart
My mower was running apx. 20 min. when it stalled. wont restart. starts for 2-3 sec and stalls again
  • 999 Answers
Check the gas cap. Loosen it a bit and try again. There is a vent built into it the hole on top plugs up ans stops the fuel flow.
Eric
Posted on Jun 24, 2009
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
How do i fix a lawn mower that start then after 2 or 3 min it will stall.
remove and clean carb , change fuel filter , check fuel tank for obstructions ,is there a problem with choke
Jul 30, 2015 | Garden
I have a 2135 cub cadet it will start and run fine for 20-30min then sputter and stall . Sometimes it will restart but only for a min then stall again. Any solutions?
Check fuel filter and be sure gas cap is VENTED,or the vents on the gas cap are not clogged , air hose it.
Take your fuel line off at the carburetor and blow back thru it to the gas tank to see if debris comes out,be real careful when or if you do this
Jul 27, 2014 | Garden
LT133 lawn tractor starts then stops. no spark,has gas filter ok,cleaned safety cutoff switch under seat. mower starts up,runs for 20 sec then stops.
Does the engine start up every time right when it shuts off, or will the engine not start until it's cooled off? And when the engine is running for the 20 seconds........ does it give any indication that it is going to stall, or does it abruptly shuts off with no indication of stalling? Let me know and I'll try to get back to you as soon as I can.
Oct 07, 2013 | Garden
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Bought 2 brand new MTD 3.5 HP 20 inch cut lawn mowers Model #11A - 020B352 Both mowers run until hot then cut out and will not restart only turn over with a squirt of fuel bulb then stall again. Both...
heres a few things to check, make sure that the oil is not over filled, you might have bad fuel,, and check the spark plugs on both to make sure they aren't fouled by fuel, if so,, clean the plug and regap them,
Jun 02, 2011 | Mtd Garden
Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Stalls when hot
it is overheating. first thing to try is ****** the timing, to run cooler, as you have just replaced the points.-plz rate -bozcro
Sep 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My Mower won't start for more than 8 sec. I changed the spark plug, gas, oil, etc. I cleaned it inside and out including the carb. left in rain for 5 min accedentaly, cleaned, na da. Help. Thanks Craftsman...
the problem is that your carbeurator is gummed from from sitting idle all winter with gas in it. Get an aerosol can of carbeurator cleaner, remove the air filter and give the air intake two squirts of carb. cleaner. Then start the mower. When it stalls again let it sit for an hour while the carbeurator cleaner works at dissolving some of that gum. Repeat the process until the mower runs again. Sometimes there is so much junk in the carb. that you have to remove it and soak it in cleaner for about three hours, and then rebuild the carb. with the proper little kit. hopefully you won't have to take this step.
Next fall let the mower run out of gas and stall then you won't have the gum in the carbeurator in the spring.
May 23, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
435 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
