Question about Kenmore Elite 45986 Front Load Washer
Coin or other object below the tub. You can hear it when this front loader spins
  • 31 Answers
Try to take the waste pipe off on the drum and tip your washer forward and see if you can see any thing
Posted on Jun 24, 2009
Their is a loud scraping noise when the washer begins the cycle. I have cleaned out the filters and there was no noticeable lime build up nor debris. The tub spins freely but the noise is persistent. We...
Have you check the pump, all front load washer drain before filling. If you have coins or foreign object inside pump the can be the cause of scraping noise. I would also check the tub for nails or object that can poke through and tub on the outer tub during rotation. Most of the time its a foreign object in the pump issue. Good luck..
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 11, 2011 | LG WM0642H Front Load
My washer will not spin!!!!!!!!
If water remains in the drum the unit will not go into the final spin. There may be a couple of reasons which I have experienced resulting in your problem. If water remains in the tub the unit will not go into the high speed spin.
1.) A coin or other foreign object could block the drain hose. Check the drain hose for foreign objects impeding the exit of the water. Shake the hose and listen for coins or a small object this unit will pass items through the pump into the hose causing blockage.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning. The hose needs to have a loop in it to work correctly.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch before the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. The pump is about $60.00 and is accessible after removing the front panel under the door. It is easy access from the front and the hose clamps will be the most difficult problem. I have a ratcheting hose clamp tool designed for this type of clamp but channel lock pliers or vice grips will work.
If the washer will not agitate during the wash cycle you will need to remove the back panel to inspect the belt and spider pulley. You will also notice a counter weight at the top of the tub. Make sure the counter weight is tight and is not loose to prevent future problems.
Feb 17, 2011 | Frigidaire GLTF2940ES Front Load Washer
I'm having a problem with my frigidaire front loading washer. It is not draining all the water out when cycle is done. Water left standing in washer.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water. Shake the hose and listen for coins or a small object this unit will pass items through the pump into the hose causing blockage.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. The pump is about $60.00 and is accessible after removing the front panel under the door. It is easy access from the front and the hose clamps will be the most difficult problem. I have a ratcheting hose clamp tool designed for this type of clamp but channel lock pliers will work.
Jan 06, 2011 | Frigidaire ATF6000ES Front Load Washer
Kenmore HE2Plus washer. It sounds like a pin or other metal object may have fallen through the holes of the drum. You can hear it roll around when you spin the drum. Is there any way to remove it without...
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2010 | Kenmore HE2 Plus Front Load Washer
Machine won't spin
Jan 18, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have the kenmore elite oasis he model # 28062. It is almost a year old and I have been noticing when it spins out it sounds like there are loose coins clanging around in it, but there is not and it is...
the rear tub.
and tub assembly.
Oct 04, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore front loader object stuck under drum
Sugest you remove the heating element and use a torch to see item through hole then pull out in the best manor possible.
Sep 24, 2009 | Kenmore 46462 Front Load Washer
Drum banging all through cycle, and much worse spinning
the rear tub.
and tub assembly.
Apr 07, 2009 | Washing Machines
Noise under drum
1) Round the door seal - happens all the time on all sorts of machines. 2) Wait for it to find its way into the hose going down to the drain pump, then dig it out from there. (You might want to check that there isn't already something stuck in the hose preventing your mystery object making this most natural of journeys). A.
Apr 08, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
64 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
