Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Honda HTR3009 riding mower runs great but won't engage in any high speeds. It slowly goes forward and in reverse - no power. When cutter is engaged, it won't move at all. What might be the problem?
  • moconnell150 Jun 25, 2009
    Thanks; The belt was on the wrong side of the tension pulley. I appreciate your input!
    Problem Solver:
  • 11 Answers
Sounds like your drive belt is slipping.
look under your engine (you may have to raise the cover to engine to do this), see if the belt that is around the pully which is on your engine drive shaft is on correctly or is in need of replacing.
Posted on Jun 24, 2009
Model dgs6500. Why does it cut off when I push reverse pedal?
is it cutting out in reverse when the cutters are engaged??
some will do this as its a safety device, more modern machines have a over ride, be it on the ignition swith or a button or even a pedal
Apr 11, 2016 | Craftsman Garden
My Lt155 ride on wont engage in forward or reverse
(Simple answer)Hydrostatic drive machines have a setting that allows you to push them. machine won`t move if this is engaged.
Also If park brake is on. Otherwise check drive belt has not snapped is loose or broken. Jack machine up and see if wheels will drive without weight of machine.
Jul 26, 2014 | John Deere Garden
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
I i have a honda htr3009 riding lawn mower that isnt getting spark wondering what could cause no spark
Don't forget the interlock cutouts that kill the engine (by turning off the ignition) if (a) there is noone on the seat when the PTO is on or a gear is engaged
Mar 18, 2010 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,224 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
