Question about Maytag Washing Machines
My washing machine fills makes a noise trys to agitate but never does, moves on to next cycle which is drain and spin, refills for the rinse, no agitation again then drain and final spin. Any ideas?
  • michaelagord Jun 24, 2009
    Maytag Performa PAVT244AWW
  • Maytag Master
  • 3,361 Answers
Need a model number.
Posted on Jun 24, 2009
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Wahing machine will not wash
the entire agitator is not moving during the wash??? or just the top section that looks like a big plastic corkscrew???
or is the unit actually just filling with water, making the motor running noises and going thru the motions of running a cycle yet not actually moving anything within the unit, then draining out as normal??
if just the top section of the agitator is free spinning instead of ratcheting as normal you'll need to replace the agitator dogs if present.
if however the units just filling and draining of water with no inner movement then more likely the drive coupling is bad and needs replacement..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washing machine refills after spin cycle
Can you hear the pump running if not the machine may be syphoning out, if the outlet is into the down pipe too far this can cause it to syphon. The outlet should only be into it by about 6". The machine will fill with more water on the rince than the wash cycle that will cause the problem. If you can hear the pump running the machine mite be over filling there may a blockage in the presure system if you take the lid off (making sure the powers turned off) you will find a round switch with a thin hose comming off it tace the hose and you should find a small bottle this may be blocked. Hope this helps you.
Dec 22, 2008 | Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Agitation issues. Everything else appears/works normally.
    I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
    Jul 03, 2008 | Maytag Performa PAV2200
    98702 Washer Drain/Spin Dead.
    My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
    Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Washing Machines Logo
    227 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
