Question about Sony XS-L120B5D Dual 12" Ported Enclosure
I have the Sony XS-L120B5D subwoofer with enclosure: sensitivity-89db RMS-600 watts Peak-2000 watts impedance-4 ohm frequency rangh-20hz-2000hz its hooked up to an Arc Audio ks 300.2 amp: class-g/h power output @ 4ohm- 180x2watts power output @ 2ohm- 350watts power output @ 4 ohm bridged-700 watts (currently hooked up as) frequency range-7hz-68KHz crossover range-55hz-5.5KHz bass boost-0-15 db @ 45Hz input sensitivity (RCA)-.25v-4v the problem is that the sound coming from the subs isn't "low and deep". its more noise than bass. the gain is not set too high. the bass coming out of it is not clean. please help
  • 7 more comments
  • cheeseballch Jun 24, 2009
    yes, it's set to low and it's at 55Hz, the lowest the amp goes down to. here is the manual to the amp:http://www.arcaudio.com/product-pdf/KS30...
  • cheeseballch Jun 25, 2009
    Here's the set-up
    amp power
    gain-min...Freq.-55Hz on Low...Bass Boost-15dB (adjusting that doesnt help much)...annel switch is at L+R Mono
    i'm pretty sure it's 2 2Ohm subs. i had troubles with a previous amp and i took it in to an expert who told me that the amp i was using before was way too weak for the subs; only putting out like 170 watts RMS. he then refered me to the amp i have now. i know its not the amp cuz the guy knew alot about this stuff. i have the amp running off 8 AWG rockford wire, would it help to increase to 4 AWG? another thought is the size of my car (1997 Saturn SL2 4 dr) it sounds great outside my car but not inside. when i stand next to my car the bass is clear and deep but inside its loud and "messy". in that case, would it help to take out one sub and just have a single 12'' in a smaller enclosure?
  • cheeseballch Jun 27, 2009
    (((sounds like you are out of phase, just reverse the wires for ONE of the
    woofers and that should do the trick. just try it, it will amaze you!))))
    what do you mean by reversing the wires?
    the subs were pre-wired in the enclosure, it wont blow my subs will it?
  • cheeseballch Jul 02, 2009
    i was wondering, if i dynamat the entire trunk, will that make the bass deeper, or instead, i was thinking of replacing the subs with 2 12'' kenwoods
  • 4 Answers
Sounds like you are out of phase, just reverse the wires for ONE of the woofers and that should do the trick. just try it, it will amaze you!
Posted on Jun 26, 2009
  • jmprestonii Jun 28, 2009
    Reverse the polarity on ONE woofer
    President:
  • Sony Master
  • 1,114 Answers
Do you have the crossover switched to "low pass"? and the frequency control below 80hz? Do you have the manual? If you need more help, post a comment and I can walk you thru it. Hope this helps
Posted on Jun 24, 2009
  • 2 more comments
  • Frank Fulton
    Frank Fulton Jun 25, 2009
    I looked at the manual, If youve got the amp set to Bridged/low pass/55hz and you are still hearing vocals, your x-over has a problem. If it just sounds lame, that's different. Check the wiring on the subs. Make sure you've got it + to + and - to - from driver to driver then to the amp. From the jpeg, it looks as though you've got L+ and R- for output, that's correct. If all that checks out correct. It's an amp problem. Was it ever working correctly or is this a new install?
  • Frank Fulton
    Also, the box was purchased like this? 2 8ohm drivers wired parallel, or is it 2 4ohm drivers wired parallel. If your not sure, if you've got a meter, check the impedance at the terminal on the box.
  • Frank Fulton
    Now, I've got a little better perspective on what your getting at. It's not really a electronics problem, but a sound quality problem. O.k.
    Well the first obstacle you need to overcome is the fact that your subs are firing thru the trunk to the interior. You need to pull everything out of the trunk and Dynamat it. That's gonna take care of alot of the vibration. Underside of the trunk lid,license plate, side walls and floor. You'll probably spend a 100 or so on dynamat and 50 or so on a good heat gun. Next, if you can, can you get rid of the sony subs & enclosure? Japanese subs can't compare to any U.S. products. Depending on what you listen to is going to decide the next step. Have you replaced the interior speakers with components and an amp yet? Look at Hertz, they are way more efficient and clean than anything I've listened to in a while and they won't break the bank. You need to upgrade your power from 8ga to 4 ga. Preferrably Streetwires, as you replace the interior speakers Dynamat the doors and floor. 400-500. Just changing subs around will never satisfy anyone who is interested in "Sound Quality" Period... My last show vehicle had over 100k in electronics in it and 68 drivers of various sizes and 7,500w at .008thd "clean" That one did the trick. Hope you have a good job or like to work alot of hours... that's what it takes.
  • Frank Fulton
    Frank Fulton Jun 28, 2009
    If it's wired out of phase, it would sound horrible; obviously horrible! and no, it will not blow a fuse. It will either sound incredibly worse, or incredibly better. Check all of the wiring from the first sub to the second sub, then to the amp. It should be + to + from speaker to speaker and - to - at the speaker. Then one + and one - to the box terminal, then to the amp. And at the amp you should be using Left + and right -
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
What is the watts
Hi.
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
Sep 07, 2011 | Jensen XS-1010 Car Subwoofer
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 23, 2011 | Car Audio & Video
What is the impedance and do they need a capactor on or is crossover built in?
Product MPN MPN RTC 19 Key Features Car Speaker Type dtrquestion.gif Component Car Speaker Function dtrquestion.gif Tweeter Size 1" Nominal Power Handling dtrquestion.gif 70 Watt RMS Technical Features Peak Power Handling 130 Watt Frequency Response 2500 Hz - 32 kHz Sensitivity 87 dB Impedance 4 ohm (Dual Coil)
please be advised you need the crossover that came with it, or you will need an active crossover dedicated to an amplifier to run these.
Aug 14, 2010 | MB Quart RTC 19 Car Tweeter
What wattage amp do I need to get good sound in a toyota corolla
Make sure it's a RMS 1200 wats not MAX watts also the Ohms of this speakers and them you can buy any amp. with the same RMS watts of your speaker and same Ohms of resistance.
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Spec for type r 10
  • 10" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 26-600 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • sensitivity: 83 dB
  • top-mount depth: 6-7/8"
  • sealed box volume: 0.5-0.8
  • ported box volume: 0.6-1.3
Nov 20, 2009 | Alpine Car Audio & Video
Need help wireing sub
Is the speaker a dual voice coil speaker? If so you can wire it up a couple of diferent ways, go to rockfordfosgate.com they have a woolfer wiring wizard that can show you the different ways to wire for 8 ohm.....4 ohm.....2 ohm....and 1 ohm...I would figure out how to get the most power out of the amp in mono mode, take that ohm load from there and see if you can wire your speaker to match it.
Oct 08, 2009 | Car Audio & Video
I have 3 hifonics zeus Size: 12 inch Impedance: Single 4 Ohms Peak Power Handling: 800 watts RMS Power Handling: 400 watts Sensitivity: 89.9 dB Aluminum Cast Basket American Spider For Reliable Performance...
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Jul 20, 2009 | Digital Audio Car Audio & Video
How big/small can the Enclosure be on RIP210DVC Car Subwoofer
Specifications Key Features Type: Component Elements: 1-Way Function Subwoofer Size: 10" Powered: Non-Powered Nominal Power Handling: 500 Watt Technical Features Peak Power Handling: 1000 Watt Frequency Respond: 35 Hz - 2,200 Hz Sensitivity: 94 dB Impedance: 4 ohm Components Woofer Material: Paper Mounting: Enclosure: Non-Enclosed Top Mounting Depth: 5.5 in.
Apr 22, 2009 | Boss RIP210DVC Car Subwoofer
Speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
Sony XS-L120B5D Dual 12" Ported Enclosure Logo
501 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
