Question about Cell Phones
I have a LG Dare cell. I have had no problems with it at all. But for some reason its not charging. I also have anothe phone, same kind, the speaker has blown out. I need to fin some to fix the bad speaker, and figure out why mine is not charging. The history on my phone is this: I found this phone in a puddle, submerged in water. I took it home, took it apart, placed it in rice for 2 1/2 months. I put it back together, turned it on , it worked. I ran to the store, hooked charger up, and its worked fine for over a year. I had the phone flashed from verizon to cricket. Do u have any ideas? Drew
  • markiepbtab Jun 24, 2009
    SOLUTION WAS WHAT I EXPECTED TO HEAR, BUT IM HOPING THE BATTERY IS WHAT IS WRONG. I STILL WOULD LIKE TO FIND SOMEONE TO REPAIR THE OTHER PHONE.
  • markiepbtab Feb 22, 2010
    THANKS, FOR THE INFO
  • 999 Answers
Hi Drew,
Couple possibilities. The battery could be dead and need replaced. I assume you have tried the other battery and or charged it with the other phone? Does the charger work on the other phone? that would rule out the charger. try cleaning the battery contacts with a pencil eraser and make sure the contacts on the charge plug and in the phone are clean also. Water is very bad for electronics and even though you dried it out there will still be corrosion inside. Worst case is take it apart and check it out if nothing else has remedied your problem. It is already broke so you cannot make it worse.
Eric
Posted on Jun 24, 2009
My lg dare (vx9700) is not turning on and when you plug in the charger it doesn't charge or anything. is there a way to fix this problem
HI lilg97 you can clean the charging port out. If you have another micro charger you can use that one to see if the phone is taking the chaerge. It could be your charger . If it is your charger you will need to replace the charger. Also you can take it to the nearest verizon and they will check to see if you qualify for their lg replacement program.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Feb 06, 2011 | LG Dare VX9700 Cell Phone
Where can i download the software for the lg dare phone i just received
Your best bet is to go to your nearest Verizon store. They will give you a software update free of charge.
May 10, 2010 | LG Dare VX9700 Cell Phone
Blank screen
its just a little hardware issue . ( an LCD strip ) kindly get it checked from the mobile workshop. it wont be too expensive.
Feb 25, 2010 | LG Dare VX9700 Cell Phone
LG dare is only charging halfway
From your description of the problem, it appears your phone's battery needs to be replaced. Because of the danger of damage to your phone from a bad battery, you should replace your battery immediately.
Your phone does not allow recalibration of your battery - as battery consumption is preset from the factory.
Thank you for contacting Fixya!
Jan 27, 2010 | LG Dare VX9700 Cell Phone
Lg dare won't charge
Best thing to do is take it to a dealer pref the one you bought it from.Try a new battery, if not try and charge the phone with a different charger.
if its not the battery or charger then its likely to be a phone fault.
I would either request money back or new phone.
Hope it helps.
Dec 16, 2009 | LG Dare VX9700 Cell Phone
The earpiece isn't working
Thats a hardware problem. It will require one speakerphone on top and a microphone at bottom both come in combo. As an expert I'd suggest you replace both. They come in combo and same charge for replacing. Rest all up to your decision.
Sep 08, 2009 | LG Dare VX9700 Cell Phone
LG dare can't hear. I can't hear incoming calls on my LG Dare.
i cant hear anything and it wont let me put it on sperker phone
Aug 10, 2009 | LG Dare VX9700 Cell Phone
Phone doesn't turn on
is it charged?? how long did you charge it for? If you charged it too long you probably over charged the battery. plz rate my solutions
Jun 02, 2009 | LG Dare VX9700 Cell Phone
Cant program lg dare
Well, assuming that you use Verizon...
Your phone should have come with a "Stop! Read This First" sheet. Mine was yellow.
Basically, you charge the battery, then dial *228
Follow the prompts.
If you use another service provider...
Call your service provider!
Feb 02, 2009 | LG Dare VX9700 Cell Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
