Question about Refrigerators
Freezer Cold but not freezing
I have a Frigidaire FRS22zrg and the fridge part isnt as cold as it usually is and the freezer is cold bot not freezing.
  • Refrigerators Master
  • 4,655 Answers
Usually this is a sign of the defrost is no taking place. On base of refrigerator behind the kick plate grill is a defrost timer. Turn the timer clockwise until compressor stops. Leave in that position for up to 30 minutes. The refrigerator should restart on its own after that wait. If not turn the timer again until compressor starts and replace timer. During the time off this should have put the refrigerator into defrost and inside the freezer compartment you should hear crackling and sizzling as the defrost heater melts the ice and water drops down onto the defrost heater. If this helps let me know. The replacement part number for the defrost timer is
215846602 If this does not help we will need to do some other test inside the freezer with the rear cover removed and power unplugged. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Jun 24, 2009
Freezer works fine but fridge isnt getting cold
make sure there isn't food blocking the vents that bring the cold air into the frig from the freezer. and make sure they're open enough.
Jul 16, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer not freezing food,and fridge not getting cold.
Hi, both compartment of the refrigerator (freezer & fridge) not freezing and getting cold means you have low or empty freon (gas) in the compressor of the refrigerator and you need to refill it as soon as possible.
Take care
Jul 14, 2010 | Frigidaire FRT17G4B Top Freezer...
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
Frigidaire refrigerator model #FRS26R4AW7 is freezing up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 03, 2009 | Frigidaire Refrigerators
American fridge not getting cold in fridge part but freezen over bottom draw
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..The fan needs to circulat the air to prevent the freezing at the bottom.
Aug 14, 2009 | Frigidaire FRT17G4B Top Freezer...
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Fridge not cold but freezer working
is the fan running in the freezer, if not find out why, is there frost on the back panel if so you have a defrosting issue bad heater bad bi-metal or bad defrost timer let me know if you need any mor help
Apr 29, 2008 | Refrigerators
Refrigerators Logo
497 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
