Question about Garmin GPSMAP 60CSx GPS Receiver
Message can't unlock maps on startup
I have just purchased a new 60cx a few days ago and have used the garmin site to register and buy city navigator map via download from site. downloads about 75% to the device then message can't unlock maps appears and download stops. Have attempted to try all methods in the FAQ including copying unlock code to text file etc and copying it to garmin folder on the device. Have emailed germin support 2 days ago with no response yet, any help would be appreciated.
SOURCE: Garmin Registration Code lost
i lost my registration code for the Garmin StreetPilot c330. How can i get it?
Posted on Apr 14, 2008
SOURCE: I have loaded Garmin Trip
Open C:\garmin directory then right click on the .exe file "Unlock wizard". Open this file as administrator and behoild it works. Even though you may already have full administrative rights as I did.
Posted on Jun 30, 2008
SOURCE: Lost Memory and Map Data
I just spoke with Garmin and they walked me through correcting the problem - very helpful. It is a matter of resetting the unit. Turn unit off, then press a finger tightly against the bottom right hand corner of screen, holding it while turning unit on. When screen comes up, let go of power button but still pressing bottom right hand corner of screen, answer question regarding deleting defaults. It is tricky and may have to be done a couple times. Then you will answer questions regarding time zones, etc. When finished with this, turn unit off and go outside in order for the unit to re-aquire satellites. When all four bars on upper right hand corner turn green, you're back in business - or at least it worked for me. Hopefully this will help, but you may want to call Garmin as they are really helpful and can explain it better than I can. Good luck!
Posted on Jul 09, 2008
SOURCE: map update
where can I get a map update for medion MD95233
Posted on Jul 25, 2008
  • 9 Answers
SOURCE: Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Posted on Mar 18, 2009
Can a New York card be used in Florida ?
Depends on the make and model. Garmon splits the US up. The chop of California for some reason.
City Navigator North America NT Lower 49 States Garmin
This one does all of North America, so check your maker.
https://buy.garmin.com/en-US/US/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt/prod1456.html
Dec 02, 2015 | GPS
Have city navigator nt on memory card in nuvi 200.When booting up get a loading stripe followed by can`t unlock maps page with ok button which puts into normal screen.Is there any trick to reading the...
sir,
we used the serial number to register on web site.
they are very helpful garmin phone is
Hours of Operation
* Monday - Friday
* 8 a.m. - 7 p.m.
* Central time (closed holidays)
Phone
* 1-800-800-1020 (U.S.)
* 1-866-429-9296 (Canada) or (913) 397-8200
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
thanks
good luck
Aug 30, 2008 | Garmin GPS
My garmin nuvi 200 says no detailed maps found
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message "No Detailed Maps That Support Autorouting."?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message "No Detailed Maps That Support Autorouting" disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for "Getting your unlock codes".If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the "No Detailed Maps That Support Autorouting" message.
Aug 14, 2012 | Garmin Nuvi 200 Automotive Gps Receiver
Codes to unlock maps on call of duty black ops "zombie" mode?
It is possible that problem may have been created because of the way Map subscriptions work. I'll verify but my latest theory is that you may have to unlock every update not just the map set. I have 4 Garmin GPS units, all 4 units use the same map sets (City Navigator - North America), and I have 4 City Navigator Unlock Codes. Plus I have 2 City Navigator Map Subscriptions that provide quarterly updates. Keeping track of Update Codes is a PIA. It is possible that each quarterly update also needs to go through the Unlock process. Apparently MapInstall doesn't do that automatically. Here are Garmin Instructions on How to unlock Garmin maps. If I am reading correctly, You have to manually add the update code to MapInstall every time you get a Quarterly Update.
This could have been done in a much more User Friendly Way!!!
It is more than a little disheartening to call Garmin Tech Support because the standard greeting seems to be "your expected wait will be over 30 minutes". That would send me to web site but I had already been there and saw no information to help with the "Maps Can't Unlock" error that was driving me crazy
Dec 21, 2010 | Cycling
Is there any updated map for streetpilot 2620 since 2008?
Yes. There is one more mapset and then there will be no more for us using the StreetPilot 2620. You are looking for the disc set North American Navigator 2009. Make sure you do not purchase the NT version. I found the item on EBAY for $81and purchased it and it worked just fine. The 2009 is the last compatible map set that Garmin released for the 2620. Be certain that what you purchase includes that unlock key otherwise you will spend another $75 on that at the Garmin Unlock Site.
Here is the link that is good for a few more days, however, may relist it. The seller is yumelectronics and the search term is 2009 City Navigator.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390193775928
Here is the search for EBAY:
http://shop.ebay.com/i.html?_nkw=city+navigator+2009
Here is the item on Garmin's site:
https://buy.garmin.com/shop/shop.do?pID=8465
Listed as:
City Navigator® North America This product has been discontinued but is still available for purchase.
It is $99.99.
Good luck, and let me know if you have any other questions.
May 11, 2010 | Garmin StreetPilot 2620 GPS Receiver
Need a Map Source CD for a Garmin iQ 3600 GPS
Please visit http://www.ebay.com
Search for the needed item and there you are.
rate this solution afterward.
Sep 04, 2009 | Garmin iQue 3600 GPS Receiver
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
Unlocking a Garmin etrex venture cx
The unit comes with a base map. You will need to purchase City Navigator software if you want more detailed maps which will show all roads. If the box contained a copy of the City Navigator and you threw away the code, you'll have to purchase another unlock code from Garmin.
May 22, 2008 | Garmin eTrex Venture Cx GPS Receiver
Garmin 350 Unlock
Did you buy the unlock key from garmin? You need this key to be able to use the maps on a specific gps (serial number) so when you update maps, you type in this unlock key and the maps are unlocked on the gps. There is a page about this on the garmin website
Feb 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin streetpilot i5
I need new map too! Can I get it through Best Buy?
Jan 21, 2008 | Garmin StreetPilot i5 GPS Receiver
Garmin GPSMAP 60CSx GPS Receiver Logo
390 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
