Question about Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem with my KP46wt510...!
Wondering if you could send me the service manual for my KP46WT510 sony projection screen TV. I've been having a problem there are green and red lines on both sides of the TV and i'm thinking it is the convergence chips but i cant find where they are...?
I have ordere the chips but i cant find where they go and i'm in desperate need of the service manual, it would be really cool if there is some way to obtain those. My email is
  • givenchy990 Nov 05, 2007
    alright i got that now i need to find out how to take the two red wires out of the module in the left rear of the G board...almost got the G board out thats the only thing thats keeping the board in.....!
  • pcalzada Mar 21, 2009
    i think the converger board went bad...i see a ghost green/red image that the automated flash does not fix. where did you get the D boar/chip, and were ou successful wiht the instatlation?
  • 1,694 Answers
They go on the largest heatsinks in your set---the " back" side,
if you look over & down......that PC board must come out to
replace IC's.......
Posted on Nov 05, 2007
  • Vista Electronics Nov 05, 2007
    1) Follow smaller diameter focus wire up front---it plugs in
    to back of focus block.....
    2) Follow HV lead from transformer to HV block. At HV block
    end, gently slide back rubber boot two or three inches...
    Push straight in toward block 1/4 in. or so and turn 1/4 turn
    ccw WHILE HOLDING IN SLIGHTLY ! Be patient,damage to
    release connection can result if you are too rough.I usually
    clamp the wire with vice-grips-push-turn-release.......T.
My sony model kp46wt510 pic looks like its in 3d, what is the problem?
Tv have a problems known as a convergence problems,it dead.The tv convergence board require it 2 STK convergence ICS and some or all it resistors are dead,require changing.These parts on the tv convergence board,must have to replaced these parts to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Aug 06, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
My sony 46 kp46wt510 panel tv has red outline on images
its more likely needing the convergence ICs replaced. You can get the convergence repair kit for your model at the following link which contains both IC the six pico fuses and four of the feed resistors, The kit comes with instructions. Heres the link.
Feb 01, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Location of the convergence circuit board on KP46WT510
they are located on the board on the left when looking in the rear of the set ( Brown Board) you can get the convergence repair kit at the follwing link which has the ICs , the six pico fuses and four of the feed resistors, plus it comes with instructions, Here's the link.
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Location of the convergence circuit board inside the KP46WT510
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors.
Check the site They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Red's are out of alignment and I can't fix them
Replace the convergence ICs and the pico fuses you can get a convergence repair kit at the following link which is for the KP46WT510 But its the same one for your model. The kit contains the two convergence Ics all six pico fuses and four resistors. Plus free step by step instructions with pictures that show how to do the repair. Heres the link to the kit.
Jan 24, 2009 | Sony KP-51WS510 51" Rear Projection...
No color and green and or purple color stripe
Yes, sounds like the convergance IC's. They will need to be replaced.
Apr 13, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP46WT510 Projection TV
pic of ic known as SDK's
41ae87f.jpg Heat sink is a hunk of metal attached to above
on a sony the convergence board is known as "d" board labeled with a big D
Jan 20, 2008 | Televison & Video
Sony wide screen projection tv model kp46wt510
Hi, replace the convergence IC`s and any discolored resistors in front of the IC`s, and you`ll be good as new, BMW Rider
Dec 30, 2007 | Televison & Video
Sony KP-46WT510 46" Rear Projection HDTV Logo
165 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
