Question about Raymarine St60 Plus Wind Display
Raymarine ST 60 wind pointer does not respond to wind direction
The unit worked last year.
Wind speed seems to work correctly. Masthead unit appears to point to wind. Attempts to linearize the system fails. The pointer stays in one quadrant while boat is turning in circle. Attempts to load factory defaults has no affect. Offset has affect of changing pointing indicator. The pointer will then not move much more than +/- 45 degrees.
  • 16 Answers
SOURCE: st60 wind instrument
You might want to double check that all of the spade connectors that are used to plug the wind transducer into the ST60 wind display are firmly plugged onto the display's terminals.
Because of the blind connection, sometimes the terminal ends up lodged between the red insulator and the spade, rather than within the spade connector itself. This results in intermittent or missing readings from one part of the sensor or more.
Also make sure the display is in Master mode. You will need to get into its setup mode to confirm this. The other possible mode is repeater, which would be used if this were a secondary readout.
Posted on Dec 28, 2007
SOURCE: Raymarine ST50
http://www.defender.com/product.jsp?path=-1|344|295761|301233|320702|746011&id=823240
Posted on Nov 10, 2008
TechnoMarine
  • 132 Answers
SOURCE: wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Posted on Jan 17, 2010
TechnoMarine
  • 132 Answers
SOURCE: sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Posted on Jan 26, 2010
  • 64 Answers
SOURCE: Clutch failure of Raymarine M81130 linear drive
Try putting 12 vdc directly to the clutch circuit. You should hear the clutch engage. If this is operating properly, then the course computer circuit has failed. If this is not working then the linear drive needs to be rebuilt.
Posted on Jun 14, 2010
I have a A22012 ST60 wind vane I need an new transducer what part number should I look for for replacement
Hi Greg!
What you're looking for is an E22078.
Here is a link from binnacle.ca, but I'm sure you can find them cheaper if you look around.
Hope this helps.
-Steve
RAYMARINE ST60 PLUS WIND TRANSDUCER MASTHEAD E22078
Jan 23, 2015 | Boating
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
How can one test a ST40 wind instrument ?
According to the Raymarine forum, aside from making sure that the spade lug connections are good and clean, there isn't a field test for the ST40. The recommended remedy is for you to send the complete unit to Raymarine for evaluation. Here's the link to that forum.
Sorry I couldn't be the bearer of better news.
-Steve
http://raymarine.ning.com/forum/topics/st-40-wind-troubleshooting
May 11, 2014 | Raymarine St40 Wind Rotavector E22047
How to programeing wind speed st 70
Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
Mar 07, 2014 | Raymarine ST70 WIND POD ONLY
Manual
Go to the Raymarine.com website, they have manuals for their products even ones that have been discontinued.
May 10, 2013 | Raymarine ST40 Wind System Rotavecta...
Autohelm st50 wind
Go to Raymarine.com to find the usermanual for these units. They should be helpful.
May 06, 2013 | Boating
Display only showing dashes ----- I have voltages on the 5 core cable from transducer to back of display .... what are correct values for these?
Try to identify if the fault is in the masthead unit or the display by using a known good unit ,or masthead or display.
Then have it repaired.
Feb 28, 2011 | Raymarine St60 Wind Vane Ducer E22078
Raymarine ST50
Oct 19, 2008 | Raymarine ST60 A22012-P GPS Receiver
St60 wind instrument
Dec 13, 2007 | Raymarine ST60 A22012-P GPS Receiver
Raymarine St60 Plus Wind Display Logo
123 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
