Question about Planar PM-9 Computer Speakers
The Planar PM-9 Computer Speakers control center connection broke. how can I by a replacement? Will Ganschow
    Problem Solver:
  • 5 Answers
Re: The Planar PM-9 Computer Speakers control center...
Yeah you are you need to replace that, or else you contact your prodcut vendor.
Posted on Nov 06, 2007
0 characters
3 Points
Blown Fuse and Need to replace
For technical help Call Bose.:
Mon. - Fri., 8:30 AM - 9 PM ET
Sat., 9 AM - 6 PM
If you're not in North America see this site:
Jun 14, 2015 | Bose Companion 3 Series II Multimedia...
I need a driver for a px2710mw planar monitor
Monitors use your video drivers it should work as soon as you plug it in...
  • Is it connected properly?
  • Are you drivers up to date?
  • Are you using a video card?
Aug 09, 2014 | Planar Px2710mw Lcd Monitor 27 1920 X 1080...
The pin broke off in the from computer port can i remove the broken piece, if so how
See this...
Jul 15, 2014 | Bose Companion 3 Computer Speakers
Logitech x530 computer speakers
the card got broke? epoxy it back together for the support and make sure all electrical connections from vol control are jumped from control to good side of board, see if u can find someone who has soldering experience if you dont an easy fix if vol control is not damaged
alternative.... search ebay u may find someone selling those same speahers
Jul 09, 2012 | Logitech X-530 Computer Speakers
Cannot find power adapter for mms171w philips system. Needs AC/AC adapter with 10v ac at 1.8 amps output. Cannot find aftermarket counterpart either. Help. Lost adapter while moving.
What does the other end of the adapter look like?
Is it a conventional circular one or is it a special port like it's thin square like or USB like maybe?
If it's conventional any 10v 1.8amp or 2 amp output should do and a lot of them are available in e-bay or if there's a Best Buy, Staples, Etc near you can just drop a visit purchase one and it should work like a charm.
However if it's not a conventional adapter you may have to contact philips and purchase one that is compatible from them.
Hope this shed some light on your problem!
May 31, 2011 | Philips MMS171 Computer Speakers
Where is my sound
Hello , I have the ba7500 for about three years now, sadly i broke the sub and control cable, now I am looking to purchase the sub and the control, or the whole system, or email me at . Thank you . Kay Ram
Apr 09, 2010 | Boston Acoustics BA7500 Computer Speakers
Altec Lansing Vs3151 Control Pod
The green connector on the control pod broke. Where can I get a replacement? The orange and black connectors still work and everything else work.
Jan 12, 2009 | Altec Lansing VS3151 Computer Speakers
Spherex IR cable replacement
After looking for this cable and talking to some of my friends - I was able to determine what type of cable it is. it is called a Mini din 9 pin male to male.
Molded Cable, Mini din 9 Pin Male to Male, 6.0 feetI bought from this guy -
hopefully you fellas from across the pond can find a place to purchase it.
Aug 03, 2008 | Spherex Xbox 5.1 Surround Sound System...
Speakers will not play
hi!good pm...hope this will help...
check if your speaker is connected in the green socket of your sound card...check the sound card driver,reinstall if needed...check the device (start>control panel>system>hardware>device manager>sound,video & game controllers) the device working properly?if yes but still your speaker will not play?...try other speaker if you have...or replaced it...
Feb 08, 2008 | Logitech R-10 Computer Speakers
Planar PM-9 Computer Speakers Logo
169 people viewed this question
Top Planar Computer Speakers Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Planar Computer Speaker Expert? Answer questions, earn points and help others
