Question about Sunbeam SNM1501R 1000 Watts Microwave Oven
SNM150RAB Sunbeam microwave it vibrates and makes noise. The microwave is in 2008 Fleetwood motor home above range. I am an RV Dealer and trying to find someone in the Fort Mill SC 29708 area to work on the microwave
  • 1 more comment
  • tracysrv Jun 25, 2009
    Everything works fine except it has a vibration and make loud noise when it vibrates which comes and goes.
  • tracysrv Jun 26, 2009
    The vibration and noise happens when your heating something or when you turn it on and there is nothing in the microwave. Also can you tell me where I can get parts for this microwave.
    Thanks
  • tracysrv Jun 29, 2009
    SNM150RAB Sunbeam microwave it vibrates and makes noise. It still heats and the vibration comes and goes weather you are heating something or its emty. The microwave is in 2008 Fleetwood motor home above range. I am an RV Dealer and trying to find someone in the Fort Mill SC 29708 area to work on the microwave
  • 258 Answers
I would say that from the noise and vibration that the fan motor is bad,
it will need a new fan motor
Appliance Repair
Day and night service
(803) 802-8784
336 Springhill Farm Rd
Fort Mill, SC 29715 35.0911 -80.9257
Posted on Jun 29, 2009
    Genius:
  • 1,341 Answers
A microwave uses as far as I can remember some rays which penetrates anything that is inside it and accelerates particles and hence causes your food to warm up.Many of these appliances differentiate between each other and it's quite normal to have these vibrations..If it is more than normal then you would need to disassemble the whole unit and check every single components especially any rotating stuffs etc..Hope this helps and please get back to me if you have any questions.
Posted on Jun 26, 2009
  • 315 Answers
It may be the magnetron, but generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
This website will help you:
http://www.microwavedisplay.com/
Posted on Jun 24, 2009
    President:
  • 1,197 Answers
We see that a lot. It's almost always a defective electrolytic on the control circuit board.
you can get the replacement parts for ur sunbeam microwave at any one of the following websites....
http://www.apwagner.com/index.php?main_page=page&id=341
http://www.householdappliance.com/
kindly rate my service........ shud there be further clarifications kindly leave a comment....
Posted on Jun 27, 2009
Microwave model SMO 43 EMG
Let Me tell its Which Brand Microwave,I Will Provide Manual Book
May 26, 2014 | Sunbeam Microwave Ovens
Maytag over range rattling and vibrating noise
Make sure you tighten all the attachment screws that may have loosened during long term usage. Make sure the fan is running properly and not causing undue vibrations. Use WD 40 on the fan.
Mar 15, 2014 | Maytag Appliances Over-the-Range Microwave...
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Mar 08, 2017 | Sharp R1875: Over the Range Convection...
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
This is a Microwave GE Spacemaker over the range model JVM1428BHC01 The RangeHood functionality seems to have a constant air flow. It started to make a noise like an electric motor that rattles,...
this sounds more like a loose winding in the main coil to me,,if its humming? the noise is becouse steel core is vibrating,,,if this is so then the coil wont last very long,,,and it cant be fixed! all you can do is fit a new coil,,,,and thats not worth the cost!! go for a new unit,,,
Aug 08, 2010 | Microwave Ovens
Need a replacment microwave oven (black) for a Dometic DOTR12C. It is built in to the RV and has the light and vent screen at the bottom, over the stove. Dimensions H 16 1/2 W 22 Depth 16 5/8 Weight 48#....
Pretty easy to change.Maybe cash and carry would be a little cheaper, or even trying an appliance dealer to see if they can get the same thing. Perhaps contacting manufacturer of microwave directly will help. (www.dometicusa.com) There was some recalls on some of the models. Are you sure it's not just sitting in an opening above the range hood. Most are just 4 screws or so, and out they come from opening above that.
Jun 02, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
My Sunbeam Over the range microvawe will self start!
You need to get it looked at professionally. Faulty microwaves are not really the thing that you should be repairing at home. They can be lethal. Find a local repair shop and get a quote for repair.
Mar 11, 2010 | Sunbeam Microwave Ovens
It runs, makes a noise with vibration, but does not hear
    If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
hope this helps you.please do rate me on this issue
Dec 30, 2009 | Microwave Ovens
Microwave Ovens Logo
91 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
