Question about Frigidaire GLGF386DQ Gas Kitchen Range
Gas stove doesn't seem to produce enough btu flame seems like a candle.Stove was converted to propane
    Problem Solver:
  • 5 Answers
Lp gas, or bad regulator
Posted on Jun 24, 2009
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
Sep 02, 2017 | Kitchen Ranges
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
Coleman model# 2430-730
It is an old one, Propane? or gasoline/camp stove fuel?
If propane and will not remain lit- replace the thremocouple- that thing beside the pilot flame that does not seem to do anything- it holds the gas valve open when flame is present.
If gasoline/camp stove fuel and will not light or does not stay lit- clean the "generator" which is under the asbestos shell. It is not even acknowledged by Coleman anymore.
Dec 22, 2011 | Heating & Cooling
Can't get stove to light
you must get some flame and put were the gas is
Sep 11, 2009 | GE Spectra JGBP30 Gas Kitchen Range
Swithed to LP
Natural Gas has a pressure at about 1/4oz psi. Propane runs at a much higher pressure 8 psi to 15 psi. For your safety do not use the oven until it is garenteed that the oven is rated for LP Gas!
Hope, this helps, Sea Breeze
Feb 01, 2009 | Kitchen Ranges
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Frigidaire GLGF386DQ Gas Kitchen Range Logo
141 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
