Question about Maytag Neptune MAH5500B Front Load Washer
Changed boot but still leaks
I changed the door boot on my neptune wash machine and water still leaks out the door.There seems to be wear on the bottom side of the door.
  • 1 more comment
  • RickeyP Nov 07, 2007
    I mentioned that there was wear on the under side of the door.So I put a bead of chalking along the wear areas.My wife did a load of laundry and no signs of leaking.The chaulking is starting to peel away any ideas of some other products to use.
  • Franita Poke
    Franita Poke Dec 27, 2007
    Same machine different problem. We are getting a good puddle of water from the bottom of the machine. Can't pinpoint where the water is coming from. Lately this machine is starting to have a lot of issues. We're trying to do all we can before having to replace it.
  • Anonymous Mar 23, 2014
    this machine fills with too much water and then starts leaking out the door when it starts washing
    Scholar:
  • 146 Answers
Are you sure it is leaking from the boot seal? The water could be leaking from the top or front of the washer and running down along the door. Pull the top off and watch the machine while it fills. Use a torch for better viewing.
Posted on Nov 05, 2007
Order/Replace Rubber Boot on Maytag Washer?
it can be quite tricky to fit, you can buy one,I would however advise to get a supply/fit quote from an engineer as he will get discount on the part, unless you are good diy person ,get hired help....
Nov 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Water leaking from front door
The whole boot whould have to be replaced. Check if there are any visible cuts or if its somewhat worn around the lip. But i would change it out. I dont know of a quick fix that would work....
Jul 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Joe
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
Jun 04, 2009 | Maytag Neptune MAH7500A Front Load Washer
Black mold on washer door seal
this is a very common problem with the neptune washers.
use a javex and hot water solution and scrub the rubber boot.
you should also do an acid wash. (hot wash with bleach, and no clothes) if there is mold on the boot it is inside the washer as well.
There is a way to prevent this. when the washer is not in use, hang a small towl on the washer door, and do not close the door.
this will allow for air movement in the washer
May 27, 2009 | Maytag MAH6700AWW Neptune Front-Load...
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Maytag front loader washing machine. Mould
How old is the washer? Did you try straight bleach on a towel and placed over the "mold" spot for about 5 minutes, be sure to wear gloves. Then scrub with a small brush being careful not to splatter bleach on yourself and rinse well. May need to replace the seal. I always leave the door cracked open after every use to "dry" out the inside and the boot. I also leave the drawer pulled out when not in use for that area to dry out as well. I have never had mold on the door seal of my Neptune washers, only the water holes above the dispenser drawer.
Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Leaks
Possible the leak comes from under the tub. Remove the wall plug & take off the rear panel. Check to see if the hose from the under the tub is secure, it could be the grip clip below the hose has come off. This is where it connects to the pump section. You need a grip plier or something to get it back on securely. If this is not the case take a good look to see where the leak comes from.
Next is the door gasket, maybe a tear.
Nov 25, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
638 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
