Question about Whirlpool DU1055XTS Built-in Dishwasher
I have a set of rollers(For Top Rack) cant install
I have a set of rack rollers(For Top Rack) i bought to replace a broke one.The part number is(ASM-8270016) which is exactly the same as the broken one. Problem is every time i try and take the old one off, it looks like i am tearing the sidewall out. Please help.what is the tip for installing these rack rollers. Thanks, Tony C NJ
SOURCE: top rack dishes are not clean
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Posted on Oct 06, 2007
THENTHEREWER
  • 131 Answers
SOURCE: ge pdw7880j10ss dishwasher lower roller
(http://www.geappliances.com/service_and_support/parts/)
the correct # for your unit is pdw7880n10ss
just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
Posted on Nov 29, 2008
SOURCE: TOP RACK WILL NOT GET CLEAN
look in the owners manual on how to clean the food particle grate on the pump.....
Posted on Dec 28, 2008
SOURCE: dishwasher doesn't clean the top rack whwn we riun it.
sounds like the jets are cloged you can try a small wire to try and unglog the jets that or you water does not have enoph pressuer hope this helps
Posted on Feb 12, 2009
kram26
  • 544 Answers
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Posted on Mar 18, 2009
How do I fix the top rack & rail for my dishwasher? The roller broke away from the rack.
Appliance parts stores will have it or can order it for you.
Nov 18, 2014 | Dishwashers
Top roller screw hole stripped
1)make certain all is clean and very dry
2)apply gorilla glue into stripped plastic hole and insert screw.
3)rig something up to keep it from moving for 6 hours or so
careful gorilla has a nasty habbit of pretty much destroying clothes and staining skin so be carefull. don't get carried away when applying it and maybe set down a disposable rag to catch drips.
but it is very permanent. Its what I would do
good luck
Nov 27, 2013 | Frigidaire Dishwashers
Dishwasher rack falls off
Could it be that KitchenAid wants you to replace the entire rack? Check with a local appliance parts supplier if you can because the roller must be a hot replacement item.
Nov 21, 2013 | KitchenAid KUDS30IXSS Builtin Dishwasher
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
Top rack rails came off the rollers
How to replace the adjuster on the top rack of KitchenAide dishwasher model number KUDS35FXSS1
Feb 03, 2012 | KitchenAid 24 in. KUDS01FLSS Built-In...
2 upper rack rollers cracked in Maytag #MDB7600AWS - cant find simple replacement rollers for inside track - 1 1/4" - of upper rack.
JP Weld works great on repairing these junky Maytag parts. Note that they don't have a replacement for these upper wheels and a guy is selling expensive stainless steel replacements. The round connector broke off of ours that holds the wheel to the rack. My wife found a plastic button that fit within the space and we glued it with JP Weld epoxy (water and temperature resistant). 10 washes later, still working great! I expect it will "heal" any other plastic parts. NEVER will I buy a Maytag again!
Sep 11, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
How do you remove the caps from the upper rack glides? I'm replacing the rollers that attach to the upper rack because one is broke.
Caps on the front ends of the glides can be pulled out. Sometimes they are hinged at the top and have a tab at the bottom to pull out. With the caps out or open you can roll the upper rack out of the glides.
Aug 12, 2009 | Dishwashers
Broken rollers inside top rack slides
We got rollers recently from Johnstone Supply, 501 Third Avenue, South, Nashville, TN telephone 615-259-3440 or 254-0702. I don't know the cost, but I'm pretty sure it was not $72. I suggest that you have the model #.
I am planning to buy some for another dishwasher at the moment.
Feb 20, 2009 | Dacor Epicure EDW24 Built-in Dishwasher
Only some cups on top rack are getting cleaned
It sounds as if you have some rollers missing on the bottom rack which lets the rack sit on the sprayer therefore not letting it spin. You should have 4 rollers on front and 2 on back of rack. If you are missing two on one side, take one from the other side until you can get some more. Just make sure you have a roller on all four sides of the rack
Jul 18, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
MDB7601AWS Maytag dishwasher
hi there,
go to www.whirlpooparts.ca and type in the model # under Repair Parts. it will show you the exploded view of the racks.
May 13, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Whirlpool DU1055XTS Built-in Dishwasher Logo
64 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
