Question about Sharp Microwave Ovens
Sharp R-3A85 microwave - Door release button does not retract.
Sharp R-3A85 microwave, When you open the door it continues to run. The door release button seems to stay stuck pushed in. Otherwise, the microwave runs fine.
MicrowaveSvc
  • 9098 Answers
SOURCE: Stuck Microwave door
In most cases this is due to a broken door opening lever or loose or broken door latch / hook parts. They can only be accessed and examined if the cover is removed from the microwave. In many over the range models, you can access the door parts by removing the control panel assembly. Sometimes you may be able to get it open by pushing up gently on the bottom of the door while pushing the button, in case you need to empty it.
Posted on Nov 02, 2006
SOURCE: Microwave door won't open when I push the button!
check door open mechanism, any broken change the mechanical parts,
Posted on Oct 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: sharp carousel microwave R-1514 F
What usually breaks is the door open lever.
On an over-the-range model, only the control panel needs to be removed in most cases.
Please unplug the oven first.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We have 2 service manuals that are very close to this model have uploaded it them our site here to help you. You will need the free Acrobat Reader to view or print them.
http://www.microwavedisplay.com/r1500_r1501_r1505_r1506_sm.pdf
http://www.microwavedisplay.com/r1512_sm.pdf
(Note: do not rely on the part numbers shown in the manual. Verify them at the Tritronics site mentioned below)
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) to open the door.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Posted on Oct 13, 2008
localwonder
  • 6784 Answers
SOURCE: Sharp R1514 - handle is stuck "in"
The mechanism has failed. simply replacing this handle(push) mech will fix this issue.
Posted on Jun 03, 2009
  • 4088 Answers
SOURCE: Latch button will not release door
Sounds like a portion of the release knob is worn or broken, or a metal piece behind it is bent.
Posted on Jul 26, 2009
Why will door not open
This happens when the latch hook loosens up and moves so that the door will not open when you press the button.
It's a very easy fix, but should be done by a repair person so that the door can be adjusted propery and no microwaves escape.
Hank
Jul 22, 2014 | Sharp Microwave Ovens
How to unlock sharp stove?
Not super familiar with Sharp Microwave ovens Convection or not,
but most microwave ovens can run into at least two reasons that they won't open and both require you to remove the cover over the whole oven - If the door has a push-button to release the door, you could find inside it has popped free of it's pivots and is not lifting up the latches on the door so you can open it, or is has actually snapped that latch. The other thing I have seen more on Panasonic microwave ovens and again moreso on the newer Inverter ovens, is that the latching assembly inside is attached to too thin a piece of metal and the metal actually bends - now your door and it's latching assembly and switches don't line up properly.
In that case you will still need to remove the cover and do your best to realign the switch assembly with the front of the microwave so that the door can click in and out easily.
May 27, 2014 | Sharp R-1870 Convection/Microwave Oven
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
Latch button will not release door on Sharp R-5H84 microwave . Push button and can pull the door open with a slight amount of force.
Jul 26, 2009 | Microwave Ovens
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Sharp Microwave R-1480 Door Release Button want open the door.
What usually breaks is the door open lever. Please unplug the oven first.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and order parts by entering your model number at the Sears parts site, but the best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Nov 19, 2008 | Sharp R-1480 Microwave Oven
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Sharp R1490 when door is open fan runs...
check door switches and control circuit.
Nov 20, 2007 | Sharp R-1490 Microwave Oven
Microwave Ovens Logo
304 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
