Question about General Electric DCVH640GJ Gas Dryer
GE GAS DRYER will not heat,
There is power to the unit, the tubler does turn, what I did find was that a ceramic heating part is broken, can this cause a no heat problem? Model #DDG9288PECWH SERIAL #VZ300970A
  • 351 Answers
Yes order a igniter from whirlpoolpartssurplus.com call me with model and i can ship it very cheap!
Posted on Jun 24, 2009
My Samsung dv5471aepxac01 dryer tubler runs even though the dryer is off
check ur power source and make sure ur getting a full 220 and not just 110 as if ur only getting half the current then u will have enough power to run the machine which only takes 110 but not enough to run the heating as that takes a full 220
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Sep 20, 2014 | Dryers
I have a GE profile Harmony gas dryer model #DPGT750GC1PL. the dryer runs but there is no heat or air coming out of the vent. diagnostics do not indicate anything wrong
see this causes and fix it. God bless you
There's no heat dot_lineone.gif 1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 02, 2012 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer won't heat up
When is the last time you cleaned out the dryer venting? May be a blockage that is causing the no heat problem. Check directly behind the dryer and also outside at the vent cap. If it's a gas dryer, it will not have a heating coil. The gas burner lights with an igniter. Does the igniter glow orange when dryer is first turned on? If not, it may be broken. Look for broken ceramic piece below where it attaches and replace. Do not touch the ceramic piece on the new igniter, as it is very fragile.
May 15, 2010 | Frigidaire AGQ7000E Gas Dryer
Ge dryer not drying but running a full cycle. sometimes turns off early
If it is electric then your heating coil is broken and needs to be replaced. If it is a gas dryer then it is most likely your electric igniter element that is cracked and prevents the unit from firing up.
Mar 14, 2010 | GE Dryers
GE Dryer DDG7580B does not heat. vents are clear, dryer tumbles, just no gas ignition. Other gas appliances working well. Help!
Replace the ceramic ignitor WE4X444. An easy fix. Nut is on the gas valve (not the line) to remove the burner assembly to replace the ignitor.
Good luck..
Jan 31, 2010 | GE Dryers
My gas dryer is not heating up I checked to see if any flames is on when its running but its not coming on the timer is turning.what needs to change
All gas dryers have a gas module. The older models (very old) have a pilot light and the new ones have what is called a GLOW PLUG and it is made out of ceramic. If this glow plug is in any way broken, you will not have any heat. The GLOW PLUG is what comes on when you first turn the dryer on and it GLOWS until the gas module actually spits out a small amount of gas and an internal combustion occurs and the flames come on full power and this is what dries your clothes. If the GLOW PLUG is fine, then the gas module could be bad. ALSO, Always check for burnt wires and check any thermostats or fuses internally in the unit.
Nov 16, 2009 | Whirlpool Dryers
GE Gas Dryer (Model DQSR 483) Drum works but does not heat
There are three things besides what you aleady checked:
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 01, 2009 | GE DBXR463EBWW Electric Dryer
My dryer ran all night and does not get hot
If gas, check the following---
1. Gas valve coils
2. Thermal fuse
3. Igniter
If electric, check the following--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jun 20, 2009 | GE Dryers
Dryer heat starts then no heat
Hi, the most common issue will be a set of defective coils but, i suggest that you run through all points and check all the listed check points before replacing the coils.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Jun 18, 2009 | GE Dryers
Heat shuts off after a few minutes
Check Replace Thermostat. The Dryer Thinks Its Not Lighting Because The Thermostat Isn't Working.
The Dryer Has A Safety Mechanism So It Wont Flood Your Home With Gas. When The Thermostat Is Broken The Unit Doesn't Detect The Heat And Shuts Off The Gas.
If You Like You CV
Jan 09, 2009 | GE DBXR463EBWW Electric Dryer
General Electric DCVH640GJ Gas Dryer Logo
170 people viewed this question
Top General Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a General Dryer Expert? Answer questions, earn points and help others
