Question about Onkyo LS-V955 System
Onkyo sr-dr2.2 cuts out quickly after starting
Same as previous posts, sounds like amplifier protection mode kicking in. Not sure how to work around this problem. Any advice would be helpful. Thanks
    President:
  • Onkyo Master
  • 1,114 Answers
Disconnect all speaker wires from the unit and power back up. If it does not go into protection, post a comment and I will walk you thru troubleshooting. If it still goes into protection, it needs to be serviced.
Posted on Jun 24, 2009
I've got an Onkyo M-282 with one channel that just died. Upon visual exam, there seems to be absolutely nothing wrong with it (the caps are all flat, not puffing, no broken components or smells...).
Likely you blew your outputs Transistors or mos fets, you cannot be sure without ohm meter. usually when one side goes out the protection kick in on both chanels
Tony
Nov 21, 2013 | Onkyo M-282 2-Channel Amplifier
Hello! onkyo SV717 pro amp that goes into protect mode. Any suggestions how to reset system?
Hi...
If you try JUST headphones (spkrs off), does it still go into protect?
If so, I would say ( from my previous 50 or so receivers) that it needs new power supply capacitors
If not, either one of your spkrs is faulty or they arent connected solidly at both ends
Jun 09, 2010 | Onkyo M-282 2-Channel Amplifier
The HT-R510 unit's overheat protection kicked in
Hey there..Sorry.When the amps are over powered they blow the main circuit and short causing the amp to turn on the right back off to protect mode.That you will have to send in to get fix..Look behind the amp and see if theres any wires touching or grounding out.My favorite amps are from onkyo and believe me i've done this a few times to 5 aps I've had.So I up graded to the tx sr 906 It rocks and will blow every speaker I have before the amp will go..Hope this helps you and good luck..Have a great day...
Apr 02, 2009 | Audio Players & Recorders
Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Oct 02, 2008 | Marantz SR-7200 Receiver
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Protection mode
you have to verify your connection cause if you are a short circuit in your different output or input the protection mode is on. it's an internal security
first disconnect all your output speakers, and restart your amplifier if the protection mode is on again try to disconnect all your input device and restart your amplifier, the protection mode should be off, so after connect one device after one to check who makes your protection mode on
Mar 31, 2008 | Onkyo TX-SR502 Receiver
Onkyo 9555 protection circuit
Make shure your speaker wiring is solid hookup to amp and spekers (NO CROSSED WIRING). Also make shure speakers are not wired in parallel or the speaker impeadance will be to low and amp will kick out.Turn speakers off then hook up headphones and crank up volume then see if amp kicks out.If it does you have an internal overload and needs serviced. If it playes ok then you must have speaker problems or wiring.
GOOD LUCK
BIGREDl
Mar 26, 2008 | Audio Players & Recorders
Onkyo TX-DS838 Issues
The problem here is that the output amplifier section has a problem. This is detected internally and the system shuts down in a "protect" mode. The output section really only kicks in when you attempt to bring up the volume. Another possibility is a problem in the "front end" where DC current is being passed to the amp section. Without takeing measurements, it is difficult to determine the exact cause. This should be a relatively stright-forward repair for a service shop and should cost about $20-$40 in parts plus the local labor charge.
Dan
Dec 23, 2007 | Onkyo TX-DS838 Receiver
Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Dec 31, 2006 | Onkyo TX-V940 Receiver
Onkyo LS-V955 System Logo
205 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
