Refrigerators Logo
A
Anonymous Posted on May 25, 2014
Haier HSW02C not cooling - Haier HSW02C
1helpful
Model # hsw02c compressor gets hot hear clicking sound but wont cool
Sounds like bad start device (relay/overload) Good Luck!
Haier Refridgerator
Your freezr drain is blocked or frozen. What you need to do is remove the ice rack then in the front of the freezer you will see 2 or 3 plastic plugs on the freezer floor remove the plugs and there might aso be some 1/4 inch screws farther in on the freezer floor. also remove the back of the back of the freezr and then lift out the bottom floor. under the evaporator you will see a lot of ice or just fod blocing the drain. I will bet its all full of ice. Carefully remove all the ice and hot water will help once you get the buk of it out. The hot water will make sure the drain is not blocked with ice. Once its al clear install in the reverse order and things should be good. This is a common problem with this unit.Good Luck
I have a haier mini fridge model #HSW02C when i plug it in it humms for a few seconds then it clicks then i hear nothing could this be the relay? any sugestions?
I would say that the motor is humming because it is not turning and the click is when the overload control switches the power off. It may be a start run capacitor blown out but it may be a seized compressor motor. have a fridge mechanic check it out.
Haier HSW02C runs ALL the time
Yes your thermostat is shorted. It's just not shutting the unit off ever. A thermostat is something you can touch as a user, so no it's not that hard to get to for replacement. Also have the unit unplugged while learning how to repair your appliance.
Haier refrigerator hsw02c does not run
These are pretty simple units. If you look on the back you will see a schematic. More or less there is an overload protector in series with the thermostat in series with the compressor. If the overload protector is not open and there is still no 120VAC at the compressor with the thermostat turned all the way up then the answer is a bad thermostat. If there is 120VAC at the compressor and it is not running then the compressor is bad. That's about it.
My Haier mini fridge (model # HSW02C) is freezing everything in it's contents no matter what number setting (1-7) it's on. Is 1 supposed to be the coldest setting, or is 7? What should I do?
Hello
Number 1 may be the warmest.Set it to 2 or 3 and give it some time,a couple of hours to level out.
If this does not work try a higher number.
If still no luck then the thermostat or sensing bulb is bad and should be replaced.
1helpful
Model hsw02c, 1.8 cuft compressor hums and then i hear a click and it doesnt do anything
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
All i ear is a clicking noise nothing comes on and the compressor gets hot
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Haier mini fridge model hswo2c not working
on its side? considering the chemicals inside the freezing elements, it needs to sit upright for 24 hours before you plug it in, or you may break it. so if thats what you mean, why is it sideways?
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
