Question about GE Spacemaker JVM1640SJ Microwave Oven
Not heating My JEM model GE Spacesaver II is not heating. I hear it turn on normal. Then, less than 5 seconds later it sounds like it is working harder. It makes more noise now than when it was working. When I unplug the magnatron, there is no noise. Diode? How do I test? Magnatron? How do I test? The fan is working. It has been above a stove so it has been working in a higher heat environment than counter top.
  • Stantec Nov 05, 2007
    I was not able to find safety information by using the above link
  • GE Master
  • 9,098 Answers
Are you saying that you're unplugging the maghnetron and then running it? If so, that's incredibly dangerous.
You're looking at 3000VDC which can kill instantly.
It may be a shorted diode. Unless you have a really good meter, you won't be able to properly bias the diode to be able to fully test it, but they usually short when they fail.
It may also be a bad magnetron. Most often when they fail and make noise, it sounds like someone gargling into an empty coffee cup. Odd, but true.
We have critical information on safety & disassembly at our site,
linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
http://tinyurl.com/gv383
Posted on Nov 05, 2007
JEM 31 is not heating
Sounds like you have a bad transformer. Magnatron should check less than 1 ohm (with wires unplugged). Diode should check resistance one way and open the other. Must have a proper diode checker for this. Check resistance on the capacitor (make sure it is discharged first). Resistance should come up then back to open, reverse and same thing if cap. is good. Check resistance on transformer windings.
Nov 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
GE profile spacesaver 2.0-does not heat and slight smell of electric burning when it is turned on. Turntable turns, fans work keypads work- just no heating and the electric odor. Filters and inside are...
MOST LIKELY YOU HAVE WHAT IS CALLED A MAGNETRON THAT HAS FAILED... IT IS THE PART THAT DOES ALL THE HEATING ...YOU DO ALSO HAVE A HIGH VOLTAGE TRANSFORMER THAT SEND POWER TO THE MAGNETRON BUT IT SOUNDS LIKE A MAGNETRON.... to be honest with you unless you are servicer it normally cost more to repair and for a few dollars more you can purchase a new one..... good luck to you.....
Jan 03, 2011 | GE Profile Spacemaker Over-the-Range...
I have a GE JE2160SF01 spacesaver microwave and clock works but the microwave does not turn on, this is the second time this problem occured the 1st time is smelled like wires were burning...looks like...
WHERE THERES SMOKE THERES FIRE LEAVE IT ALONG.
TO REPAIR THE MICROWAVE WILL COAST YOU MORE WHO EVER WORKS ON IT WILL HAVE TO REPLACE BURNT WIRES
AND POSIBLY A SWITCH...TAKE MY ADVICE BUY A NEW ONE
WITH WARRENTY AND YOU WON'T HAVE TO WORRY ABOUT SMOKE IN THE HOME.
Feb 05, 2018 | GE Microwave Ovens
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver over the range microwave oven
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacesaver micro not heating
Your magnetron, HV diode, Capacitor, or control board maybe bad most of these components run with high voltage and difficult to test without the proper equipment
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
104 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
