Question about Canon Office Equipment & Supplies
Network ScanGear can't discover Canon IR 3220
New PC on network (both XP Pro) - installed same software as old one (which had no issues connecting to scanner on IR 3220) - Adobe Acrobat 6.0 and ScanGear 1.5. Also tried version 1.51. Scangear tool cannot discover printer / scanner - tried entering printer IP directly, still no luck. Both 1.5 and 1.51 show up as choices in the Acrobat Devices list, however I get an error message that says ''no scanner was selected for scanning, select one using the scangear tool''. As an aside, the Canon EFI Job Monitor also cannot '''see'' the printer via IP.
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Posted on Sep 01, 2009
    Sniper:
  • 118 Answers
Try to download latest version of color network scan gear from canon website. install it and before discovering, put the scanner online. hope this can help
Posted on Jun 25, 2009
I want you people to teach me how to install and to use a network scanner on canon IR2520.
Install the scanner driver (Canon Network ScanGear) found on the bundled CD. I assume you already assigned an IP address on your copier. Run the Network ScanGear software, the one you installed earlier. Click Discover or you can manually type the IP address of your copier. If your copier is discovered, click Test Connection. Remark is displayed that your scanner is ready to use. Click OK to save the settings.
Now, run 3rd party software (eg Photoshop). In File > Acquire > (Select Canon Network ScanGear). A window will pop up and you are ready for scanning. Note: If error "Scanner is offline" occurs, go to your copier and press Scan > Remote Scan > Online.
Jul 06, 2011 | Canon iR 2016i Black and White Copier
Canon IR3300 Scanner
1) install Network ScanGear software from canon officiall site, search under ir 3300, and among all drivers there is scangear too.
2) when you install scangear, open it and press discover button, but the light scan on copier must be on, and set on ONLINE.
3) Then over eg. word2003 go to insert-pic.-from scaner or cam.-choose scangear- custom insert.
Jun 14, 2010 | Canon (6981A002AA) for imagerunner 2200,...
My scan gear software cannot list the cannon ir2022 copier. The Ethernet network plug also doesn't blink when connected to the slot in the copier? please respond me with ermiasabate@gmail.com thank you
first are you sure that you have correct network cable, plain utp if you use copier over hub or similar and cross if You are connected directly trough PC.
Under cmd, type: ping xxx.xxx.xxx.xxx. "x" means the IP adress, if you have replay without 100% loss, the copier communicates fine with pc.
If not use cross cable and connect directly to pc or laptop.Do not forget adjust laptops gateway, and subnet same as copiers.Then try again from setup of printer drvivers and scangear. Do not forget to press discover under scangear properties.
Dec 26, 2009 | Canon iR 2022 Printer
Scanning question
The Machine must be connected to a network.Download Network Scangear software driver from the Canon webside,install it on your destop.After installation open the Scangear tool and select the discover button.The scangear will search for the machine on the network.As soon as it has discover the machine the ip address will show in the tool.Select the Machine and close the scangear tool.Select the scan button and set it to online.
Now you can scan in to a program like word or exel by Insert a picture from scanner.
Dec 14, 2009 | Canon imageRUNNER 5000 Copier
ScanGear Not Detecting Network ImageRunner
the scangear by network is not for this machine .only for usb.
May 20, 2009 | Canon imageRUNNER 1023iF Black and White...
HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
May 06, 2009 | Canon imageRunner C3100 Copier
I have no manual and I need to figure out how to scan on this machine. Canon Imagerunner 50001.
Download the network scangear from the canon web site.
Install the scangear on all the computers you want to scan to.
On the scangear tool there is a discover icon,click that icon and wait till the ir 5000 is picked up by the network.Select the machine in the scangear tool.Now you will be able to scan to mirosoft word and exel like you normally do with a scanner.
If the scangear tool was unable to discover the machine,the network settings of the IR must be checked.
Hope this help.
Mar 09, 2009 | Canon imageRUNNER 5000 Copier
About scan
First your copier must have a networkcard installed and link to your network.
Download canon network scangear from the canon website.
Install the scangear.In the scangear tool select discover and your copier will apear in the block,click on the copier and click select.
From Word or Exel you will be able to insert it as a picture by selecting the scanner.
Network scangear link
http://software.canon-europe.com/software/0028070.asp?model
Jan 21, 2009 | Xerox CopyCentre C20 Black and White...
5,002 people viewed this question
old marine
old marine
