Question about RCA RP3722 Clock Radio
Alarm How do I shut-off the alarm? I cannot find the instructions and I want both of the alarms to show as off, at the moment, they are both set for seperate times because I cannot figure out how to completely shut them off.
Press CANCEL and within 3 seconds, press WAKE1.  The display should change to OFF.  Repeat for WAKE2 after the clock symbol in the center of the display has cleared.
Darlene
Posted on Jul 09, 2008
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Mar 26, 2011 | Audio Players & Recorders
I have a Uni-com wireless doorbell, model 55075/SC352R. I would like instructions as I'm not finding it easy to reset things and have inadvertantly set the alarm and don't know how to turn it off!
With the display in normal mode showing the time, date and temperature and with the double dots flashing each second, press the MODE button. The first press will give you the option for setting 12 or 24 hours on the time display. The second press should bring up the setting for the alarm time. Press the SET button once and it flashes the hour for the alarm. Press it again and the minutes for the alarm will show. Pressing the SET button a third time lets you set the number for each musical tone choices for the alarm. A fourth press will ' set' the alarm so the alarm time will show, plus the number representing the ring tone you selected below the alarm time. Normally what you would do next is press MODE again 3 times to return to the ordinary time display. But if you want the alarm off, instead of doing this, press SET a fifth time and this will set the alarm time to 'off' and the display for the alarm will show '-:--' now press MODE 3 times or until you see the ordinary time display with the double dots flashing. You can check the alarm is off by pressing the ALARM button - it should still show '-:--'. The ALARM button is only for showing the alarm time which has been set, not for actually doing the setting. A quicker way, starting from the normal display with the seconds flashing on the time, is to just press the ALARM button once, then press SET 5 times then MODE 3 times.
Aug 27, 2010 | Vacuums
Need set up instructions for the KATEC #38 travel alarm clock
I bought one of these for $3.00. I found it in the clearance sale aisle at my local Wal-Mart. The instructions refer to it as being an "Automobile Clock."
In the instructions, "M" refers to the "Mode" button, "S" refers to the "Set" button, and "D" refers to the "Date" button. These are the instructions that came my KATEC #38 travel alarm clock:
1. In normal mode, there will show hour, minute, second and week. Push "D" to show date and push "S" to show alarm-time.
2. Adjust alarm-time: Push "M" two times to enter into alarm mode. Push "S" to choose hour and minute. Push "D" to adjust the right time. Finally, push "M" to return.
3. Adjust real time: Push "M" three times to enter into adjust time mode. Push "S" to choose second, minute, hour, day, week, and month in order. Push "D" to adjust correspondence number for right volume. Finally, push "M" to return to norm-al mode.
4. Sport Function: Push "M" for one time into sport watch function mode. The beginning state is show as 0:00:00. Push "D" to enter into recording time. Push "D" again to stop. Push "S" to return to the beginning mode 0:00:00.
5. Adjust ON/OFF alarm mode. In normal state, push "S" and "D". You can choose alarm on or off. When alarm operates, the alarm symbol will be displayed on.
Jan 09, 2010 | GE 74801 Clock Radio
Just installed smart siren kit, worked ok for 1
Harley alarms, while a decent alarm system, are notoriously hard to set up. On a new installation I have sometimes had to run the set-up routine 4-5 times. I hope you have an owner's manual and/or good instructions. Keep trying to set the alarm up from the beginning. If you miss a key or time limit it's not unusual to have the set-up fail and you have to start all over. Disconnecting the battery will screw things up, so be careful.
Oct 02, 2009 | 2002 Harley Davidson FLHTCUI Electra Glide...
No power to the coil
I just did a quick check on a wiring diagram and found something that at first glance makes no sense, but I'll tell you anyhow... One diagram shows power to the coil from the alternator. The other shows power coming from the ecu. I would first do a quick check... Turn the ignition key three times, leaving it on the third time (do not permit starter to engage while doing this) The check engine light will flash in code 1 flash+ #1 etc numbers are seperated by a short pause. number sets ie:23 are seperated by a longer pause. Write down #s and check in a manual for meanings. If you have not disconnected the battery at any point, pay attention to a code 12 that shows batt disconnect (which I would read as a power disconnect) also, anything else that is even remotely related. Got an alarm with engine disable in it??
Dec 31, 2008 | 1993 Jeep Cherokee Country
How To Set/Shut Off Alarm On Tommy Bahama Watch RLX1003
On RLX1003 Hold S1 ( bottom right ) and then press S2 ( Top Right ) to toggle through the options ( Alarm and Chine )
Dec 20, 2008 | Tommy Bahama Bimini Tide Watch
Emerson Smartset alarm clock
Hi - You can download the manual from the link underlined in blue below:
CKS3528
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jun 25, 2008 | Emerson Smartset Clock Radio
Lost instructions for Emerson
to change the alarm mode setting for alarm 1, hold alm1 setting button and press the alarm mode button until the day indicators show thedesired mode setting. weekday only,weekends only,or everday operation. release the alarm mode and alm 1 setting buttons and the display will return to correct time.
Dec 05, 2007 | Emerson CKS2237 Clock Radio
False battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
Feb 03, 2007 | Balance CN6555 Notebook
RCA RP3722 Clock Radio Logo
134 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
