This product worked fine for about 2 months then all the sudden just quit on me. When I unplug the unit and plug it back in the indicator with the three squiggly lines blinks about 3 times then goes off. I tried resetting by holding down the power button, but when I press start the green light comes on and does nothing. I have tried cleaning the filters with all the brushes that came with it and still nothing. I plug it in, the red light blinks 3 times then I press start and nothing? Any help would be....well.....helpful, thanks.
-   Bionaire BAP1500 air purifier. When plugged in it oscillates, but does
nothing else. No noise at all. No fans are on. Any suggestions.
-   Guest
Jan 08, 2009
-   bionaire bap 1500.red light flashes when turned on.press button and green light comes on but fan does not work-   mick pearson
May 11, 2008
-   Same problem here. Open it up and everything seemed intact. Red light flashes momentarily during initial plug in. Machine will not reset and fan not working.-   Guest
Apr 20, 2008
-   Bionaire BAP1500 air purifier. When plugged in it oscillates, but does nothing else. No noise at all. No fans are on. Any suggestions.
-   Cleaned filters. Checked power source, powerd source is ok. The modek number I have is BAP1700. It did not appear on the list so I chose BAP 1500-U-   Guest
Purchased this Bionaire Permatech Air Cleaner BAP1525 for my mother Christmas 2007. Worked temporarily, but since it blew cold air, she turned it off. Tried to use it this spring and green light came on but unit would not work. Called Jarden (Bionaire), faxed proof of purchase, received new unit one week later. You might want to try this. Customer service rep said if I was unable to locate sales slip she could still send me a replacement. Worth a try!
Solution #2
posted on May 11, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
fan won't run any speed. Ionizer works, oscillating works... any ideas? When turning on and holding...
(More)
fan won't run any speed. Ionizer works, oscillating works... any ideas? When turning on and holding on switch I get a red led that flash twice? Some kind of error code?
i just cleaned my bionaire BAP 1700, I can hear it working but i do not feel the air, another issue...
(More)
i just cleaned my bionaire BAP 1700, I can hear it working but i do not feel the air, another issue is that the rotating motor is jammed some how
Cleaned the filers. Reset the filter so the light would go off and now the unit doesn't work. Tried...
(More)
Cleaned the filers. Reset the filter so the light would go off and now the unit doesn't work. Tried unplugging, plugging in and nothing. All the lights work on the unit but nothing happens.
I have recently purchased a bionaire bap 1550 air purifier. Is it normal for the recirculated air...
(More)
I have recently purchased a bionaire bap 1550 air purifier. Is it normal for the recirculated air only to come out of the left hand side of the front grill
My BAP1500-U oscillator motor internal gearing has stopped working. It gets to a certain point then...
(More)
My BAP1500-U oscillator motor internal gearing has stopped working. It gets to a certain point then starts clicking away. The motor appears to be one sealed component. Where can I get a replacement motor? Thanks Sman
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
