Question about HP Hewlett Packard Pavilion Slimline S3100N PC Desktop
RAM replace on Hp pavilion slimline s3100n PC
I'm trying to replace my RAM but it looks like the dvd drive is in the way. I've tried to remove it but it's stuck somehow, there's a small latch on the top that can lift and let me wiggle it a bit but the bottom is really on there. Is there a screw or something i'm missing? I don't want to risk breaking anything. Can you help?
    Problem Solver:
  • 6 Answers
Ok, what you've got to do are the following.
1. Remove outer cover. (you've obviously already done this)
2. Remove holder for personal storage device.
Pull up brown/black lever untill the unit lifts up and out
3. You can now see black screw holding in DVD/RW Drive - remove it.
4.Lift latch that you described
5. Push DVD Drive forward until you can access the memory
Posted on Jul 16, 2009
  • firblog Jul 16, 2009
    P.S you must also remove the front cover of the machine before you can move the DVD Drive forward...
    President:
  • HP Master
  • 1,996 Answers
Here are the HP support instructions to replace the ram in your model. Sometimes the memory is just tight in the slot. Make sure you have pushed on the latches at both ends of the slot, and this will help to lever the card up from the slot as you pull it out.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 24, 2009
Hp desktop alarming when turned on
Open the lid. Blow (or vacuum) dust away from CPU heat sink.
Take out RAM clean the edges with thick cloth. Put back and try again.
Jun 17, 2014 | HP Hewlett Packard Pavilion Slimline...
My hp s3100n slimline, the screen stays blank but the power come on. The CD spins and the hard drive but there no startup information on the monitor. Please I would be willing to send a small donation to...
Go to this LINK.
i only post the link because there arre several steps to try to resolve your quest.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 12, 2010 | HP Hewlett Packard Pavilion Slimline...
Hp pavilion slimline s3100n doesn't display on the monitor. boots fine and fans spin and stuff, it just doesn't recognize its own VGA output. What do i do?
Hi
First,try hooking it up to an external monitor if you have access to one.Unfortunately,we need video to start checking for what may be wrong.
Try the monitor and post back to let me know what happens,and if it shows on the external display we can start looking at potential problems and fixes.
Bob
Aug 21, 2010 | HP Hewlett Packard Pavilion Slimline...
Looking for any complaints regarding the motherboard for the HP Slimline s3100n.
HERE is a whole site of listed complaints regarding the computer you listed. HP Slimline s3100n. I hope this helps and is what you were looking for.
Jun 22, 2010 | HP Hewlett Packard Pavilion Slimline...
How do I get the DVD out of my s3100n slimline pavilion HP in order to install add'l ram
Most slimeline cases have DVD that remove from the front. That is you will have to remove the front plate of the computer to slide the DVD out. Close to the inside corners on the front usually are compression fit plugs that snap into place, ocassionaly screws but not often. Take your time and slowly push them outwards once you have all of them loose on one side you can gently rock the front back and forth until the other side dislodges.
It is important to not use excessive force or you could break the pins in which case you will need to have some glue handy.
Feb 05, 2010 | HP Hewlett Packard Pavilion Slimline...
I want to upgrade the RAM, and when I opened the desktop the dvd is positioned over the memory slots. I CANNOT FIGURE OUT HOW TO REMOVE THE DVD TO SWOP OUT THE RAM
see if there the motherboard is secured onto a rack that can slide out of the casing. most newer computers have this feature. if not, you will have to unscrew the dvd drive from the casing to get to memory slots. unplug the drive, find the mounting screws, and remove the drive. remember to plug everything back up (power, interface cable, digital cable if present).
good luck.
Oct 15, 2009 | HP Hewlett Packard Pavilion Slimline...
How do i remove the dvd from an hp s3100n desktop.
You need to take the cover off the computer on both sides. Normally the optical drive is secured by four screws, two on the left and two on the right. Take those screws out and slide the drive forward enough to get to your memory stick. You may not have to unplug the cables, but if you can't slide it out far enough you will.
Jun 27, 2009 | HP Hewlett Packard Pavilion Slimline...
How do i remove the dvd from hp s3100n
Hey there, sounds like it is stuck in your drive? Simple, there is a small hole in the front of the drive, put a paperclip in there to push the drawer out
HP Pavilion Slimline S3100n keeps shutting down to powersave
It may be a virus or trogan problem. DO clear the Internet explorer cache and browsing history. remove all unwanted programs using add remove programs. please reply to me if u can solve with thos solutions
Apr 06, 2009 | HP Hewlett Packard Pavilion Slimline...
I need to reset the ram on a hp pavillion slimline
The DVD drive should have one or two small phillips head screws on the side that will allow you to slide the drive out through the front of the PC. Just be careful that you don't damage the ribbon cable when you do this.
Mar 19, 2009 | HP Hewlett Packard Pavilion Slimline...
HP Hewlett Packard Pavilion Slimline S3100N PC Desktop Logo
1,692 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
