Question about Maytag Dryers
LP Gas dryer willnot heat. checked fuzes, lint filter etc. Is gas have a thermocouple?
  • 6,784 Answers
Check the following to address this issue further.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer or Control module
Replace if defective (note: uncommon problem).
Posted on Jun 24, 2009
Fridarire affinity FAQE7001LW dryers runs no heat
Good Morning Friend,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is running but there is no heat. Before calling a technician, check the following solutions:
    1)Make sure that the two house fuses your dryer is attached to. If one of the two fuses is blown, the drum may turn but you won't receive any heat.
    2)For Gas Models Only: Make sure the gas supply valve is open, make sure there is enough air supply to support the burner flame, and make sure the LP gas supply tank is not empty or there has been a utility interruption of the natural gas.
    3)Check the lint filter, the ducting that leads outside, as well as the outside vent for any lint that might be clogged inside. This can cause a no heat issue, due to your dyer is not getting a good air flow.
    4)For Electric Dryers Only: Make sure your dryer is connected to a 208 volt circuit.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 29, 2014 | Frigidaire FAQE7001LW Dryer
FFLE1011MWO will not heat
Good Morning Steven,
I understand that the dryer on is not heating on your Frigidaire laundry center, model# FFLE1011MW0. Before calling a technician, check the following solutions:
    -Best Regards-
    WP
May 29, 2014 | Frigidaire FFLE1011MW Electric...
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
No heat..gas not fire up
My Whirlpool has a thermal fuse in back in the air duct in case the lint filter doesn't get cleaned.
There are other causes too----
Apr 25, 2009 | Dryers
Dryer quits after being used for a while and won't turn back on
It is overheating.
You are luck it puts out any heat.
You didn't say if it was Electric or Gas?
If electric, the the airflow thru the dryer is restricted or a sensor is bad and 'lying' to the CPU. Check the filter, check the hoses for lint, check the outside vent flap to be sure it isn't stuck (possibly painted) closed. The air has to BLOW a certain CFM or neither ELEC or GAS type will turn on or shut off prematurely (Gets too hot too quick).
If Gas, the thermocouple that tells the CPU that the 'heat is on is 'lying' or the sensor that tells the CPU the Air movement is OK' is bad.
My dryer wouldn't heat because a thermocouple in the exhaust pipe was lying - stuck ON and telling the dryer it was already hot enough. ;-) and my Furnace turned on and off for 10 minutes b/c the airflow sensor was jammed.
If you do the troubleshooting, do NOT forget to unplug first!
Mar 27, 2009 | Dryers
Kenmore dryer wont work
Electric or Gas?
If electric, the element is gone or a fuse blew or the airflow thru the dryer is restricted or a sensor is bad and 'lying' to the CPU.
Check the filter, check the hoses for lint, check the outside vent flap to be sure it isn't stuck (possibly painted) closed. The air has to BLOW a certain CFM or neither ELEC or GAS type will turn on.
If Gas, the pilot isn't lit or the electronic ignition isn't firing or the gas supply valve is bad/stuck or the thermocouple that tells the CPU that the 'heat is on is 'lying' or the sensor that tells the CPU the Air movement is OK' is bad.
My dryer wouldnt heat because a thermocouple in the exhaust pipe was lying - stuck ON and telling the dryer it was already hot enough. ;-)
Dryer does not put out any heat
Electric or Gas?
If electric, the element is gone or a fuse blew or the airflow thru the dryer is restricted or a sensor is bad and 'lying' to the CPU. Check the filter, check the hoses for lint, check the outside vent flap to be sure it isn't stuck (possibly painted) closed. The air has to BLOW a certain CFM or neither ELEC or GAS type will turn on.
Mar 26, 2009 | Dryers
My dryer stopped heating. Everything else seems to work. It still runs, but only feel cold air.
Electric or Gas?
Dryers Logo
53 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
